Author Subject: Nissens radiator
bk
Hi guys-
Got a bit of a dilemma with the cooling systems on both my gti6 and my dturbo. Coincidently they both relate to the bottom radiator hose.
Just fitted a new Nissens rad to the dturbo and realised the bottom hose fitting on the rad is different to the bottom hose fitting. The hose has 2 clamps that lock into the rad but the Nissens rad has a metal clip and seems to be some sort of quick release mechanism. Was at the local pug dealer and they were no help with locating the correct hose for the job-has anyone else had this before?
Interestingly my gti has the type of bottom hose connection that I need but pug can't get this hose anymore and mine has started leaking-can you get them elsewhere?
Thanks in advance
Bk
Posted 12th Aug 2014 at 18:42
Niall
The one with the two clips is ph1/2. Ph3s use a push in type hose with a metal clip to hold it in
Posted 12th Aug 2014 at 18:45
if its leaking at the connection get a new o-ring.
if you have a new rad with the later connection type just fit a new hose.
Posted 12th Aug 2014 at 18:48
