displaying posts 76 to 100 of 135
Pages (6): first .. 3 [4] 5 .. last
Author Subject: Overheating
cully
Post #76
to prove both fans work
work out which relay is 1508,
remove the relay
and bridge pins 3-5 in the socket without the relay plugged in but leave all the other relays in
you should get slow speed with the ign off
Posted 19th Sep 2014 at 12:33
Chr1sch
Post #77
Ok so the saga continues!
Bridged the one relay (I thought whats 1508) only one fan spun, bridged the other one (clearly 1508!!) and BOTH fans spun! So at least i know i have working fans and wiring...
Checklist:
1) Working fans
2) New black 5 pin relay
3) Other 2 relays must work as when i switch them over the one fan still operates - although this isnt a 100% guarantee?
So in conclusion, if the bridging cully advised above works, does that conclude it must be the bitron thing?
Posted 19th Sep 2014 at 14:41
cully
Post #78
double check F12 F15 and F2 fuse inside the car as that will stop the high/low speed fans working
if that is ok
your next port of call is the fan controller (bitron box) as this is the unit that controls the three fan relays and the A/c relay
it is located above the horns on the N/S inner wing
you may just have crap connections in the plug as it often gets drowned under the wheel arch or it could be dead Sad
Posted 19th Sep 2014 at 15:16
Chr1sch
Post #79
You sir are a legend!
Thanks I'll check that next...
Posted 19th Sep 2014 at 15:52
Chr1sch
Post #80
Interestingly a/c is dead too...
cully
Post #81
most AC on 306's is dead due to loss of pressure from coroded lower condensor pipes
AC will fail safe if there is an issue with it i wouldnt think its related more of a second problem....can of worms
Posted 19th Sep 2014 at 16:37
Chr1sch
Post #82
Thanks again cully,
Would this be the same?!
Look at this on eBay:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=300635839683
CITROEN SYNERGIE XANTIA PEUGEOT RADIATOR FAN ECU 9633609680 CCTuP5/BVA2 BITRON
Posted 20th Sep 2014 at 20:12
cully
Post #83
honest answer is i dont know you need to check the part numbers
Posted 20th Sep 2014 at 20:29
Post #84
1338 A1 is the unit listed for a git6, temps of 96/118 listed for it, it is listed for an XU10J2 806, so it will work, a TD one is listed at 90/101 for early models or straight 118 for later ones.
Posted 20th Sep 2014 at 20:40
cully
Post #85
good man i trawled service box and couldn't find the bloody thing Wink
Posted 20th Sep 2014 at 20:51
Chr1sch
Post #86
Thanks guys, sounds like I may be better off looking for the exact one rather than this one then? (Appreciate you said it would work, not clear if that was as a compromise or equally well as the actual one for a gti6?)
Posted 20th Sep 2014 at 22:08
Chr1sch
Post #87
Welshpug do you have the part number for 1138 a1?
Posted 20th Sep 2014 at 22:12
demondriverdan
Post #88
Aha, now I know what you mean by the bitron unit. Will see if my Dad can take if off the shell for you.
Rallye Race Car
Posted 20th Sep 2014 at 22:14
Post #89
errrrrrrrrr.....
LOL
Posted 20th Sep 2014 at 22:20
Chr1sch
Post #90
I get what you're saying Welshpug but most seen to have a longer number like this :
PEUGEOT 206 406 CITROEN COOLING FAN RELAY . MANUFACTURED BY BITRON . PART NUMBER 9633609780 . COLOUR BLACK . ITEM IS USED & IN GOOD WORKING ORDER
Posted 20th Sep 2014 at 22:46
Chr1sch
Post #91
Thanks! Only 2x10mm bolts!
Posted 20th Sep 2014 at 23:10
demondriverdan
Post #92
He's going to check tomorrow, will let you know Smile
Rallye Race Car
Posted 20th Sep 2014 at 23:30
cully
Post #93
the longer numbers are normaly the manufacturers numbers
peugeot use a 6 digit letter system ****.** Smile
Posted 21st Sep 2014 at 08:02
Chr1sch
Post #94
Oh thanks, every day is a school day lol
Posted 21st Sep 2014 at 09:38
demondriverdan
Post #95
Here's the box I've got on the car. Any good?
Rallye Race Car
Posted 21st Sep 2014 at 17:01
Chr1sch
Post #96
Cully/Welshpug can you advise? Mine says bitron on it rather than g Cartier?
If this has come off another gti6 is it going to be the same?
Cheers guys!!!
Posted 21st Sep 2014 at 18:38
Chr1sch
Post #97
Incidentally I've looked at the connectors on my bitron one and they were all fine bar one which was totally covered in white crusty stuff. I've cleaned it and tried unplugging the brown plug but no avail...
I have also bridged the one relay to check and both fans definitely spin up, there's nothing else bar the bitron I should now be suspecting is there?
If someone can confirm if that box above is ok I'll buy it ASAP for sure :-)
Posted 21st Sep 2014 at 18:41
Chr1sch
Post #98
Here's mine
Posted 21st Sep 2014 at 18:44
demondriverdan
Post #99
The lugs line up on the two boxes but that could just be the design is the same. Yours looks like a Ph3, which is what this came off.
Rallye Race Car
Posted 21st Sep 2014 at 21:36
Chr1sch
Post #100
I think mine is a 2.5, cully/welsh either of you have any idea if it would be a feasible replacement?
Dan, how much do you want for it posted? (The one above on eBay was £14 as a point of ref but they do vary..)
Posted 21st Sep 2014 at 22:41
