Tried to fit an OMP lower brace to my gti-6 but the engine is constantly resting on it so had to take it off again. Does anyone know a solution to this?
Cheers,
Will
306xsi has attached the following image:
displaying posts 1 to 25 of 41
| Author | Subject: Lower Brace |
306xsi
Junior User Location: Suffolk Registered: 08 Feb 2006 Posts: 90 Status: Offline |
Hi guys,Tried to fit an OMP lower brace to my gti-6 but the engine is constantly resting on it so had to take it off again. Does anyone know a solution to this? Cheers, Will 306xsi has attached the following image: |
aaron6
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Yeah new one had two bars rather than one for more rigidity________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
aaron6
Mine are rigid. But are solid bar. As they are only small the weight difference wasn't to bad, plus the bar was free from work... The guys who run them seem to love them. But Phillipm does make the from two bits of tube so will be lighter than mine. But if you want to modify your omp a welding shop would knock up something using your existing ends pretty quickly.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
306xsi
Cheers for the advice. Can't understand why it won't fit though. Thought maybe there was something wrong with the engine mounts and it was sitting lower than it should? Will keep an eye out for something to replace it. OMP lower brace for sale..... anyone? |
aaron6
For whatever reason the sump is a lot lower than all the other models and OMP obviously didn't take the gti6 into consideration. Put a wanted thread fora phillipm one fella.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
The OMP ones aint worth a w**k anyway. Get a double tube PhillipM one on there and i promise you you will not regret spending the extra |
Cjwatson27
I almost brought one of these from eBay glad i didn't now ________________________________________ Old pugs don't die they just get faster |
osm2121
Regular Location: Montevideo Registered: 02 Nov 2012 Posts: 229 Status: Offline |
With this bar theres no chance to fit the protector for the carter, under tray, or however its called, right? |
aaron6
You can probably cut it about to cover most of the bottom of the engine.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Tarmac terror
Regular Location: Southampton Registered: 20 Mar 2014 Posts: 458 Status: Offline |
Anyone used the Ultra Racing lower brace?? I know these guys have a good reputation with the Skyline community for bracing products. Just wondering what the fitment was like on 306 if anyone has tried one?.TT |
orta
Senior User Location: East Mids Registered: 02 Sep 2006 Posts: 860 Status: Offline |
Are we saying we're not to buy an OMP Lower brace Bcoz it doesn't fit?!________________________________________ CLUB BLACK RALLYE||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar|| |
barrym
Senior User Location: Westcliff-on-sea Registered: 26 Jun 2014 Posts: 502 Status: Offline |
Just a thought but have you checked the top engine mount? If it has suffered the usual failure then the engine will be sitting a bit lower than it shouldEDIT: seen you have already thought of this ________________________________________ China D Turbo HDi daily chargerBlack Rallye occassional toy |
aaron6
The omp one will not fit. 100% sure of that. That's why I've had to make them in the past and phillipm still does sometimes.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Yeah, as aaron says, plenty of people have that issue with the OMP ones, that's why I started making ones that fitted to start with.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
orta
What much do they go for ;-)________________________________________ CLUB BLACK RALLYE||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar|| |
![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Tarmac terror
PMSL...Sounds like the price Nismo would charge!! (Skyline scene anecdote )(which, disturbingly, some folks pay!!) TT |
orta
And thought those £1200 lions on eBay were expensive!________________________________________ CLUB BLACK RALLYE||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar|| |
Tarmac terror
Sounds like it's time someone started another run of lower braces...I'd certainly be up for one!! TT |
aaron6
I can't make in bulk or I would do. I'm sure if you discuss with phillipm and start a bulk buy thread he'll look at making them. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
vandal.pr!
Junior User Location: Zadar, Croatia Registered: 18 May 2008 Posts: 63 Status: Offline |
I need one too...________________________________________ Peugeot 306 s16 '97--- |
fatlapit
Id like one tooooo________________________________________ |
Cjwatson27
Would one of these work with a v6 ? ________________________________________ Old pugs don't die they just get faster |
no.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
