Author Subject: Longman btcc cylinder head
pete_rallye
click
Happy to end the auction early for a sensible offer...
Lap of the 'ring
Posted 13th Sep 2014 at 23:37
daver6
Hmm did they spend a long time on a flow bench or something?
Wishbone Polybushes available
Posted 14th Sep 2014 at 13:51
pete_rallye
I would imagine when they were in development they did yes, by the time Longman retired I imagine he (or whoever did them) could do them with there eyes closed but that didn't stop Longman charging BTCC prices for them.
Porting seems to be a strange thing, some people claim it takes days sitting at a flow bench and charge £k's, others do it by sight for a few hundred quid and there doesn't appear to be a noticeable difference in the finished product. I guess it depends a lot on how 'perfect' and equally matched you want each port to be. Think it's safe to say with this been a BTCC head it would be the latter...
Lap of the 'ring
Posted 14th Sep 2014 at 13:59
A lot more work went into the heads other than just porting !
Posted 14th Sep 2014 at 15:02
daver6
Such as?
Posted 14th Sep 2014 at 16:02
Thinner valve guides , 3 angle valve seats, opening up the chambers, cleaning, adapting the heads to run solid lifters and lairs cams, full strip down / rebuild etc prob a whole host of other things
Posted 14th Sep 2014 at 16:33
Tingtong117
How much are you after for it?
You must have a rough price in mind?
Posted 16th Sep 2014 at 17:38
pete_rallye
I'd like to see £100 for it. Got s**t loads of watchers on eBay though so might let it run and just see what it goes for...
Lap of the 'ring
Posted 16th Sep 2014 at 17:41
edhunter
Is it possible to use stock valves for this head ?
Posted 17th Sep 2014 at 20:35
pete_rallye
Not sure is the honest answer. The valves it used are G+S valves, listed for a 405 MI16 here-
http://www.gsvalves.co.uk/assets/recmastervalvecatalogue.pdf
They are about £270 for an engine set which isn't bad at all. They are 0.5mm oversize so not much bigger than standard valves. I would personally say standard valves would be ok as long as they are cut to match the seats but wouldn't guarantee it... The stem size is standard.
Lap of the 'ring
Posted 17th Sep 2014 at 21:49
Mi16 valve stems are bigger than a gti6, inlet valves are larger but exhaust valves smaller than gti6.
Posted 17th Sep 2014 at 23:06
pete_rallye
Ah well, that's what they are listed as, dunno what they are, probably first used in the 405 supertourers or something... stem sizes are definitely standard.
Lap of the 'ring
Posted 17th Sep 2014 at 23:09
Rallyewoo
Did this sell?
Kev
Posted 18th Jun 2015 at 07:50
pete_rallye
The one listed above did sell but I have recently listed an identical one with similar damage. Search eBay and you'll find it.
Lap of the 'ring
Posted 18th Jun 2015 at 10:17
Rallyewoo
Ok cool
Kev
Posted 18th Jun 2015 at 10:22
