I know the pump isn't the problem as I've wired it up to the battery direct and it turns.
Replaced key fob batteries and fitted a new realy. All to no success.
Any ideas anyone? Immobilisor?
| Author | Subject: Immobilisor???? |
brend
Newbie Location: Sc**thorpe Registered: 03 Sep 2014 Posts: 27 Status: Offline |
Just put the new gearbox on the xsi now the car wont start. Theres no signal to the fuel pump, engine cranks but wont fire up.I know the pump isn't the problem as I've wired it up to the battery direct and it turns. Replaced key fob batteries and fitted a new realy. All to no success. Any ideas anyone? Immobilisor? |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
push the inertia switch behind the battery |
brend
Tried that but it feels pretty loose like im only moving the Plastic part a little bit like the buttons already pressed? |
check the CL fuse.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brend
I have found a white 2 pin connector at the front of the engine but cant see where it goes |
brend
Whats the cl fuse and where is it? |
brend
I assume u mean the central locking fuse then. That's fine as it still locks and unlocks on the key. I'm really stuck on this and quickly running out of ideas |
Does it lock on the button?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brend
Yer it locks and unlocks on the button still, even got new batteries |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
Was it a new fuel pump relay you fitted ? Crank sensor plugged in ? ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
brend
Ive replaced the fuel relay yesterday. Were is the crank sensor on these? Im assuming near the starter motor? Cheers for the help as well lads very much appreciated |
brend
If it is that crank sensor im going to cry I think after all the time ive spent yesterday p**sing about |
brend
Right without looking i'm assuming the crank sensor is the red plug sat on top of the gearbox under the battery box. But there is a random white plug on the front of the engine leading towards the starter motor its 2 pin. Would this be a dead plug or needed as I know on gm engines they have a similar plug for the autobox models |
brend
These are the 2 connectors I cant find were they go. The red 1 looks like it leads to the thermostat but the 2 connectors are already in brend has attached the following image: |
brend
This is the 1 I think is for the thermostat brend has attached the following image: |
Neither will stop it working.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brend
I did think that but wanted to get the obvious out the way before I ring the auto electrician |
Try locking then unlocking with the fob, at least you know the alarm is disarmed that wy________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brend
I've tried all that even the BSI reset even though i'm not 100% sure what it achieves haha. I think a lot more f**kin around is in order. I don't think its anything I've missed as I've been over it all about 20 times now. Just can't get my head round why it wouldn't send a signal to the fuel pump unless it was immobilized....... Starting to get to me now I want to get back out on the road in her, gob smacked at how well it drove, even with a nakered diff |
Theres no bsi on a 306 ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
steve h gti-6
Location: Carterton Registered: 04 Dec 2006 Posts: 1,583 Status: Offline |
Check your trickle feed 5amp fuse which goes to the imob, on my phase 3 it was F6 in the inside fusebox. ________________________________________ "Gotta Love The 6"According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL ! |
Rich E
Post 14 is the AC clutch and post 15 is either for the third coolant temperature sensor or is an unused plug (believed to be the breather heater for cold climate models).Crank sensor would be the most likely suspect. The 306 immobiliser doesn't cut the fuel pump. ________________________________________ Rich |
pauldoubleyou
Junior User Location: Glasgow Registered: 13 Sep 2014 Posts: 78 Status: Offline |
Check all the fuses. All. Check you havent got the plug for the crank sensor or something similar accidentally plumbled into something wrong, CTS for example. Theres sensor plugs all over the engine bay. Pretty sure all it needs to run is a crank signal. ________________________________________ PaulHiding with Pride |
cully
check the fuel pump fuse in the engine bay fuse box |
brend
Well I've tested all the earths tonight and everythings fineGot a new crank sensor coming tomorrow so will try that. I've took the one off that's on the gearbox and it seems fine no damage or corroded wires but as we know looks can be deceiving!!!!! Fuses are all fine as well. |
