It pains me to do this but I'm breaking my rally car
it's still complete but will be stripped over the next couple of weeks.I'm not going to go into loads of detail on each part nor list every tiny item so please ask for more info/pictures or for things I haven't listed. Postage available on everything,big items will obviously be expensive though! all offers considered.
Safety devices c44 cage £provisionally sold
Rose jointed bottom arms, new joints and boots with 1900 hubs, good bearings £350
Challenge spec front billies £provisionally sold
PLR gravel springs £40
Top mounts with baker rubbers £provisionally sold
306 Tarmac rear billies £120
Beam with 21mm PTS bars, 205 arms with good wheel bearing/hubs, solid mounts ££provisionally sold
Rear calipers, m1144s, brembo discs £60
Magnex 4-1 manifold, properly welded around flange, needs a new flexi £40
Motordrive side mounted buckets, black with red centres £250
Pts sump guard, well used £50
Fuel Tank + bonded on fiberglass guard £30
Bare 1900 8v engine, stripped, checked and re-gasketed + recon head around 5k ago, really strong £140
Complete engine with ancillaries £provisionally sold
Good 1900 Shafts, recent cv on one, new intermediate bearing £60
Suede sporty flat Steering wheel + boss £30
15 row (I think) heavy duty oil cooler, sandwich plate, pipes + modded rad cowl/ fan £80
Bbm engine mounts incl. ally rear mount £60
Complete Braided lines, incl. fittings for hydraulic h/brake and bias valve £30
Pas set-up incl. rack etc £60 (unless pump goes with engine)
Tran-x LSD set up to suit £provisionally sold
AB motorsport close ratio box, be4 casing, 4.44FD £provisionally sold
allanallen
