Author Subject: Floaty feeling on 6 when driving..
willy1971
Morning fella's...I still have a floating feeling on my 6 after replacing the following....bottom ball joints, tie rod ends, coil springs and P-bushes on the wishbones. Had the tracking done and tyre pressure is correct so after doing all of this I still have the same problem....getting fed up now as I have double checked everything over and over again. The only difference is the tie rod ends which are metal instead of the original plastic ones...will that make a difference in any way?
Cheers in advance.
Posted 17th Oct 2014 at 09:18
dampers that will be or mismatched spring rate to dampers.
Posted 17th Oct 2014 at 09:43
aaron6
How are you rear beam mounts? They can make for floaty handling.
What air pressure do you run in the tires and are you still on 15's?
Posted 17th Oct 2014 at 18:35
Moved to Suspension. Smile
Posted 18th Oct 2014 at 10:31
