Author Subject: gearbox diff bearings
pete-gti
Do these need a good firm tap to fit onto the diff? Or should they fit ok nice and easy , think I might have ordered wrong ones , ones I have are JL69349A/310/Q SKF Metric Taper Bearing 38/63/17 , but been told SKF JL69345F310Q Metric Single Row Taper Roller Bearing 38x63x17mm are the correct ones , ain't they both the same size?
Posted 31st Oct 2014 at 19:25
o.e were Timken or SNR branded, varied throughout production.
Doesn't matter what the brand is as long as they're the correct size, you need a press to fit them properly, though if tolerances aren't too tight you may get them on with a suitable drift.
certainly should not go on by hand.
Posted 31st Oct 2014 at 20:08
pete-gti
Will give these a tap with a drift see if they go on ok :-) what's the with same size but different part numbers by skf?
Posted 31st Oct 2014 at 20:21
different manufacturer?
Posted 31st Oct 2014 at 20:27
edit, nope, timken also list one under that number.,
Posted 31st Oct 2014 at 20:31
pete-gti
Give these bearings a good tap tomorrow should go on , don't see how different part number will make any different if bearing is same size :-)
Posted 31st Oct 2014 at 20:35
Rich E Forum Admin
quote:
[quote="pete-gti"what's the with same size but different part numbers by skf?
Looking at the data on SKF's website regarding the two there are some small differences in roller dimensions
Posted 31st Oct 2014 at 20:52
pete-gti
Even when they say both are 38x63x17. There's about £5 different ,
Posted 31st Oct 2014 at 21:04
