Author Subject: solid bottom engine mounts
Hawkesfire
Hi i have seen these before but can not find anything on the search engine here so looking to get one for the rallycross car but are they Ok or do they cause problems or snapping things?
Also who makes these and i have seen some have a small bush in them?
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 6th Nov 2014 at 13:22
completely solid or harder 'uprated' ones?
colin satchell made my completely solid one from turned ally. combined with the other solid mounts it made for serious vibration but did the job perfectly
Posted 6th Nov 2014 at 13:37
Constella make them I belive?
Posted 6th Nov 2014 at 14:48
jamiek_uk2000
Phillipm used to do them, but I don't think that he is on here any more. Not sure if anyone has a contact for him
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 6th Nov 2014 at 17:01
http://306oc.co.uk/forum/user-152.html
HTH
  • Posted 6th Nov 2014 at 17:02
    Cjwatson27
    You after a solid aluminum one for the bottom mount ?
    Posted 6th Nov 2014 at 17:20
    Hawkesfire
    Yes please you got one if so how much ??
    Marty
    Posted 6th Nov 2014 at 18:20
    Cjwatson27
    I'll have a look see what i paid, can you collect ?
    Posted 6th Nov 2014 at 19:55
    fatlapit
    any turning firm can make them
    Posted 6th Nov 2014 at 22:30
    fatlapit
    ebay
    Posted 6th Nov 2014 at 22:34
    fatlapit
    Posted 6th Nov 2014 at 22:38
    Cjwatson27
    Got one here already fitted in a housing
    Posted 8th Nov 2014 at 13:57
    allanallen
    I used a solid nylon bush in my 205 rally car, teamed with the harshness of the paddle clutch it eventually snapped the lower engine mount fork, seriously ruined my rally Sad
    If you're going to fit one I suggest you leave the little rubber bush in the lower fork. I'd personally go with a baker bottom mount and nylon fork bush though.
    Facebook
    Posted 9th Nov 2014 at 08:58
    rallyeash
    I had a solid engine mount and the housing snapped after. While. Changed the mount/housing with a hardened rubber one. Much nicer drive
    309 3dr K20 Type R
    Posted 9th Nov 2014 at 19:19
    aaron6
    I'm with allanallan. Stilly had very solid engine mounts and the stress was transferred straight to the chassis nearest the mounts and put some substantial cracks in. I had to weld large plates on to stop it happening again.
    Posted 21st Nov 2014 at 07:35
    superchargedblack1997gti6
    Phillip m built some custom mounts classified as semi solid, I have used this and a constella solid item I'd typically say for you're car hawkesfire I'd go fully solid? If you're after a Phillip m semi solid give me a pm.
    Thanks
    Posted 21st Nov 2014 at 09:38
    BigTallPaul
    Group A Baker BM here -----> http://www.bakerbm.com/306.php?data=engfbusha306
    for just £17 !
    Good Luck Marty.
    Posted 21st Nov 2014 at 16:24
    for just £17 !
    Good Luck Marty.
    thats just the fork bush not the large one.
    if you want solid you need to do all three, otherwise any flex will be transmitted into the shell violently through the solid one.
    Posted 21st Nov 2014 at 16:30
    Hawkesfire
    Thanks gents i have got a solid unit now will try next year as currently space framing front end to get some castor on the car and then we start to remove whole rear floor section from the cage back over.
    We will also be looking to drop the engine height as well to get the COG as low as possible .......
    Lots of work !!!!!
    Posted 22nd Nov 2014 at 13:48
