Red Rallye - Rolling "restoration"Wishbone Polybushes available
| Author | Subject: Power Steering Circuit Fault |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Got a fault code up for the power steering circuit, any idea's?________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
daver6
I can't even think where the sensor is ?________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
Sensor is on the high pressure pipe. Look down near the oil filter and you'll see it.________________________________________ ![]() |
daver6
You're right! Thanks Dan. Could be why it was stalling during tight and slow parking ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
Common problem. You're sensor is probably goosed. Leave it connected and see how you get on.________________________________________ ![]() |
stan_306gti6
Disconnect the sensor, no more stalling then or fault code. ![]() Massively common problem. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Extensively common problem.________________________________________ ![]() |
