Author Subject: Wipers only have 1 speed.
devere
So I have the problem of my wipers only going 1 speed... Put the stalk to the first setting, and they go across as normal, but the next two settings don't vary the speed at all.
Anyone point me in the right direction of what I might be looking for? Or is it most likely going to be a change for another wiper motor setup?
Posted 11th Dec 2014 at 19:12
Relay??
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 11th Dec 2014 at 20:25
pugheaven
Have you changed the motorcycle recently? What phase is your loom?=
If you have a phase 2/3 loom and use a phase one motor intermittent doesn't work and the next two settings are the same speed
If you have a phase one loom and 2/3 motor the same happens as above
Posted 12th Dec 2014 at 14:20
RetroPug
I changed the motorcycle on my 306s...solved a lot of electrical problems.
Posted 12th Dec 2014 at 16:04
pugheaven
Bloody auto correct.... Wiper motor
Posted 12th Dec 2014 at 16:40
devere
This could be it....
I have the cut down wiper motor that fits around the roll cage. Which I believe was used in the car as a phase 1 job. The loom I'm using came out of a phase 2/3.. So would be phase 2/3...
On this basis, you think by using the motor out of the phase 2/3 car would solve the problem then...
Bit of a strange issue to occur just through different phases!
Posted 12th Dec 2014 at 17:29
There's no change in part number, so its more likely to be a stalk or relay fault.
Posted 12th Dec 2014 at 18:17
pugheaven
Yep using a phase 2/3 motor should solve it but you will.still.need to have the auto wipe sensor and loom if not you will have the same problem.
Just put the sensor under the dash if you dont want it on the screen
Posted 12th Dec 2014 at 18:19
pugheaven
That's strange as its the same fault I had when I had phase 3 looms with phase 1 motor, changed the motor to the one I got out the phase 3 and problem solved
Does the motor not have anything to do with intermittent on the phase 1s and rain sensitive on 2/3s
Posted 12th Dec 2014 at 18:22
I have a similar issue using a zx wiper in my phase 3 loomed car
Posted 12th Dec 2014 at 20:49
devere
Im not sure whether my car ever had the rain sensor on it anyway!? I never had the auto wiper option on the car??
Its a rallye loom if that makes any difference?
Posted 12th Dec 2014 at 20:53
I need to work my wipers out. The cage is in the way too on mine
Posted 12th Dec 2014 at 21:16
