Author Subject: radiator thermostat coolant
curlz1987
Hi I have a 306 gti 6 iv just replaced the thermostat because I thought it was stuck open I have had problems with cutting out wen hot like 90degs. And stutters sometimes wen gunning it. Also my heating seems to be luke warm not hot. Iv bleed the system all three bleed points. I dont seem to be getting much pressure in the top rad hose. I cant c it being the head gasket as I dont loose any water plus there is no water in the oil.cars runs around 78 degs at 30 to 80 mph. Thermostat works fine opens at 83 deg. Any help welcome
Posted 17th Dec 2014 at 21:30
Probably needs a new matrix or at least it flushing out.
stuttering could be a number of sensors on the engine.
Posted 17th Dec 2014 at 21:34
curlz1987
Its running through ok and both pipes are hot coming out where the thermostat is. The bleed screw top left bulk head flows out out no probs. Just dont know why theres not a lot of pressure in the top rad hose. Normally hard to squeeze once up to temp but its got hardly any pressure at all
Posted 17th Dec 2014 at 21:47
only gets hard when the hg goes tbh.
try a new cap anyway
Posted 17th Dec 2014 at 21:51
curlz1987
What rad cap?
Posted 17th Dec 2014 at 21:53
Thanks for your message.
Your feedback is important to us.
  • Posted 17th Dec 2014 at 22:00
    curlz1987
    Heating is bothering me more as its coming into winter. Set on cold its cold wen set on hot it just about comes out luke warm. Theres no air locks coolants coming through the matrix fine dont understand why it's not hot
    Posted 18th Dec 2014 at 06:03
    curlz1987
    Any 1 on here
    Posted 18th Dec 2014 at 16:04
    have you removed the matrix pipes and back flushed the matrix?
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 18th Dec 2014 at 16:09
    curlz1987
    Just the bleed srew and return pipe from heating matrix both flowing fine. Car runs around 75 to 78 deg wen doing over 30 is that normal
    Posted 18th Dec 2014 at 18:44
    Could it be the air direction part in the heater box area behind the dash? Not sending air through the matrix to heat it up.
    Posted 18th Dec 2014 at 20:00
    Just the bleed screw only won't show you how it's flowing.
    Other than that the flap as said above, is there anyway to see it moving without removing dash?
    Posted 18th Dec 2014 at 20:05
    curlz1987
    It might be. not sure how to get to it 2 check it out though. will av 2 google it 2 c where it is. It must open a bit cause it warms up just not as hot as ud expect it 2 be. Like it's set on 21 deg and not full heat.any 1 know if u can get 2 it behind cdplayer. Cheers for the help ppl
    Posted 18th Dec 2014 at 22:48
    curlz1987
    Posted 18th Dec 2014 at 22:49
    curlz1987 wrote:
    Any 1 on here
    Very few these days.
  • Posted 18th Dec 2014 at 23:19
    curlz1987
    Yeah I think it maybe the flap was playing around with it on way to work every time I turned it to cold then hot again it would get hot then next time it would go cold or luke warm so might be possibly sticking a bit
    Posted 19th Dec 2014 at 10:01
    ad
    Might be a sensor in the dash itself, also the little fan/ temp sensor in the roof by the light might need a clean as it can clog up with dust ect and get a false reading....
    It could be a number of things though, we all know what these cars are like.
    How much antifreeze have you put in? Is it the right stuff ect ect
    Good luck.
    Posted 1st Jan 2015 at 12:50
    Rich E Forum Admin
    Moved from Feedback
    Posted 1st Jan 2015 at 13:36
    LOL never noticed till last post, I wondered what you ment, I just thought you felt like been a bit random
    Posted 1st Jan 2015 at 14:00
