230 hp 2.1 16v XU 205 rallye on jenveys
Project thread here309 3dr K20 Type R
| Author | Subject: 309 Type R |
rallyeash
Went to a motor factors this morning and they came up with the bush I'm after for the gearbox... Think it might be from a golf or something. ![]() ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
rallyeash
So I've been playing with the gearbox mount and head scratching on what to do, the bush above wasn't really strong enough and sagged which I wasn't keen on. So I decided to make something similar to the pug setupTwo studs stick up here, the rear one is a lower and the original mount is a step down design. Couple of spacers I had bring it back up level. ![]() I cut out a section of steel drilled holes to mount, drilled through the centre and added the original peugeot gearbox stud. I welded it on the underside, few tacs around the top and painted it ![]() I then made a mount for the peugeot gearbox mount, I'm using a standard pug one but if it's not soft it's then dead easy to swap to a bm item ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
rallyeash
So got the engine mounts finished off and some good progress309 GTI arms and Gaz coilovers handed down from the 205 ![]() Which come with eccentric top mounts ![]() Back on 4 wheels (borrowed from the 205 while it's apart) Engine back in permanently sump clearance is fine ![]() ![]() Subtle - ish ![]() ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
rallyeash
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
How do you find time to do all this? Some bloody good progress mate |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
pugheaven wrote: How do you find time to do all this? Some bloody good progress mate thats what i was thinking, good project, i always liked sandys one :-) ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
rallyeash
Make time! If you don't have the time it's not high enough on the priority list! And time becomes an excuse for not doing it. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
fatlapit
looks awesome________________________________________ |
eddy_gti6
Post #35
Nice to see something a bit different in a 309. Everyone seems to be going V.tec these days!!! ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
rallyeash
Post #36
Purchased a new DTA s60, Spa 0-9k tacho and lotus 45mm bodies from Jorg!Also Had to drive past Merlin's today so purchased a Simons centre and back box in 2.5" along with two 2.5' pipe. Going for a straight centre exit! ![]() Picked up a GTI tank and pump as will be injection ![]() Got the dimensions of the civic radiator today and will fit nicely In the 309 bay and isn't much bigger than a 309 one plus has the benefits of the right size and position outlets. Ordered one and will be turning up tomorrow so big weekend planned on the 309! ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
rallyeash
Post #37
Full day on the car todayCivic radiator drops in like so. ![]() Exhaust fabricating... Now this is the first time I've tried to make an exhaust, I don't have access to any proper equipment except welder, grinder etc. Because I'm running the standard tank the exhaust has to run through the gap for it, else it'll sit low. So an angle was required, I cut 3/4 of the way through with a grinder and cut out a wedge shape, closed the gap and welded it back together like so. ![]() Exhaust boxes didn't have mounts on them so made some out of 6mm bar and welded them on, also had to weld hooks onto the boot floor to hang the exhaust. ![]() Had to angle the pipe work up after the beam so the box sits up nice and high. The front section will have 12 inches or so cut off, silencer added and the cut off section will mate upto the manifold. Will wait till I get it before doing that section. ![]() How it'll fit ![]() Need to get my hands on a 4-2-1 civic manifold to finish the system. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
fatlapit
Post #38
spot on ________________________________________ |
rallyeash
Post #39
mechanical_repairs
Post #40
Lovely weldingCarl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
oldbrownshoe
Seasoned Pro Location: Holon Israel Registered: 08 Aug 2008 Posts: 1,795 Status: Offline |
Post #41
Very impressive mechanical capability,but did you took in your considerations the new weight distribution in a light car ? a dressed K20 weight 326 lbs from what i picked. bare one weight 280 lbs, with tranny it's about 400 lbs, what was the weight of the original engine ? http://www.lotustalk.com/forums/f25/toyota-rover-honda-k20-weights-555/ http://honda-tech.com/hybrid-engine-swaps-18/k20-weight-835977/ ________________________________________ French military victories?Did you mean French military defeats? |
Post #42
any chance of weights in kg? we are not Americans, or old ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #43
400lb ~ 181kg, probably no more than a built up gti6 engine, which is 35bhp short of the k20is 127kg correct for a bare alloy blocked k20? a bare 1.9 8v xu is 72kg, a gti6 bare will be around 110! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
oldbrownshoe
Post #44
So 132 kg for Mi16 engine, is for dressed configuration ?________________________________________ French military victories?Did you mean French military defeats? |
jimmyrallye
Seasoned Pro Location: portsmouth Registered: 19 Apr 2008 Posts: 3,144 Status: Offline |
Post #45
Awesome welding skills exhaust looks spot on ________________________________________ "Police arrested two kids yesterday, one was drinking battery acid, the other was eating fireworks. They charged one and let the other one off." |
Post #46
oldbrownshoe wrote: So 132 kg for Mi16 engine, is the for dressed configuration ? for an alloy MI16 that is probably not far off, the gti6 fully dressed is around 150, a lot of heavy stuff gets bolted to them! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
oldbrownshoe
Post #47
O.K , so what was the more nimble better handling 309 ?the one with the weak 72 kg 8v engine or the 30916v with Mi16 engine lump ? ________________________________________ French military victories?Did you mean French military defeats? |
rallyeash
Post #48
I'm not sure on the weight, but working with it I would say it's lighter than a iron XU engine. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
rallyeash
Post #49
So had a fun delivery this morning. New S60 DTA ![]() New Spa 0-9k tacho, I'll be making up a custom dash to control everything. Requires digital speedo and all that. ![]() Lotus 45mm bodies, on a XU inlet. ![]() Choice of 40mm or 60mm trumpets ![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
jorg
Senior User Location: Wallasey Registered: 10 Jun 2007 Posts: 816 Status: Offline |
Post #50
enjoy! ________________________________________ 306 2.1 S16 Tarmac Rally CarProject thread: http://www.306gti6.com/forum/showthread.php?id=143956 |
