Author Subject: drive shaft bearing
pete-gti
I'm not sure if my drive shaft bearing is inside the hosing far enough or not
How far is it ment to go in? Is it met to be flush with this side?
Posted 27th Dec 2014 at 18:16
When you tighten the nuts up it will pull the bearing home.
  • Posted 27th Dec 2014 at 18:49
    not advisable really, only m7 bolts and they bend easily.
    best bet is to clean both parts thoroughly and you'll feel/hear it clunk home, the size of the collat holding the bearing in place varies so they won't all look the same.
    Posted 27th Dec 2014 at 18:58
    fatlapit
    stick some copper slip in that will help it
    Posted 27th Dec 2014 at 20:55
    pete-gti
    it might all be good but im not sure , the bearing is flush with the hole on the side you push it threw, will get some pictures see what you guys think
    Posted 28th Dec 2014 at 11:24
    When ever I remove a shaft I always clean up the bearing with either a scotchbrite pad on a die grinder or some emery cloth. Then cover it in copper slip. Goes in easy as anything and comes out next time.
    The bolts will pull it in all the way if you do them up evenly. But as said if it's to tight going in then I wouldn't force them.
    Posted 28th Dec 2014 at 14:02
    Never had any problems just using the bolts to pull the shaft into place
    Posted 28th Dec 2014 at 14:48
    pete-gti
    will get a picture tomorow , i greased it up a tad bearing has gone into the housing just waiting on getting some new nuts for it , just not sure if its far anough in if anyone has a picture be apprecaited
    Posted 28th Dec 2014 at 15:50
    pete-gti
    I've tightened the bolts up now and its pulled it in a fair bit , pretty sure its now where it should be :-)
    Posted 29th Dec 2014 at 18:47
    bearing looks seated, but why two nuts? standard ones are locking type.
    Posted 29th Dec 2014 at 19:08
    pete-gti
    Found by using a over size nut it fitted into the hole nicely to act like a washer , then put the normal locking nut on found it a lot easyer to tighten it up as it gave me more room for the ratchet and be Easyer to remove if ever need to , when I first removed these I had to grind bit of my 11mm long reach socket down to fit into the recess hole as it wouldn't go in
    So I've just done this to makes it easyer for me lol :-)
    Posted 29th Dec 2014 at 19:26
