Just hard to see if its made a good joint or not
| Author | Subject: cat to manifold joint |
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
Yeah, the gasket is beveled and will show slightly.________________________________________ Less than 24 hours to go! |
Looks good to me________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
yup just wind the nuts till they bottom out.nylocs will be useless there though, the o.e locking nuts are more suited to that application. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pete-gti
Just used what came with the kit , alright the same sort that you use on the drive shaft bearing housing? |
thats the ones.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ad
Regular Location: High Wycombe Registered: 15 Aug 2004 Posts: 284 Status: Offline |
Not that it really matters but i thought there should be 4 washers and one sits on top of the spring against the "flange"I also make my own bolts with thread as i always find that the bolts supplied with those kit don't do up enough for my liking, they always seem to let a little fart noise out when putting your foot down..... |
not if you buy the o.e kits ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ad
Ive tried all sorts over the years and still find my "home made kit" works just as good.An 8mm threaded bar with a 10mm nut on top wound down a few mm, cut down the middle of the threaded bar with a hacksaw down to 10mm nut. Then burr the ends over the nut with a hammer and your done- cant remember if i put a washer on the bottom of the nut or not so it doesn't pull through. its always worked for me. Or you could just buy a kit..... |
how do you get an m6 nut on an m8 bolt?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pete-gti
seems ok will no for sure once its running |
ad
welshpug! wrote: how do you get an m6 nut on an m8 bolt? I get a 10mm nut with an 8mm thread and put it on.....simple. My old man has a lot of stuff in his shed. |
ad
ad wrote: welshpug! wrote: how do you get an m6 nut on an m8 bolt? I get a 10mm nut with an 8mm thread and put it on.....simple. My old man has a lot of stuff in his shed. A bit like this if the photo uploads... ad has attached the following image: |
ad wrote: Not that it really matters but i thought there should be 4 washers and one sits on top of the spring against the "flange" I also make my own bolts with thread as i always find that the bolts supplied with those kit don't do up enough for my liking, they always seem to let a little fart noise out when putting your foot down..... I used the smaller ones, was a complete and utter bas**rd to fit them tho ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
welshpug! wrote: how do you get an m6 nut on an m8 bolt? Maybe he ment a 10mm head as in a 10mm socket. Where's the bloody common sense gone to with some people, unless you allready knew that and was just been awkward as usual ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
ad
buzzbrightyear wrote: welshpug! wrote: how do you get an m6 nut on an m8 bolt? Maybe he ment a 10mm head as in a 10mm socket. Where's the bloody common sense gone to with some people, unless you allready knew that and was just been awkward as usual That is what I meant, I can't get technical. 10mm head, 8mm thread, bobs your uncle..... |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
cough! 10mm head 6mm thread ![]() or 13mm head with 8mm thread |
ad wrote: buzzbrightyear wrote: welshpug! wrote: how do you get an m6 nut on an m8 bolt? Maybe he ment a 10mm head as in a 10mm socket. Where's the bloody common sense gone to with some people, unless you allready knew that and was just been awkward as usual That is what I meant, I can't get technical. 10mm head, 8mm thread, bobs your uncle..... I knew exactly what you ment anyway lol ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
pete-gti
Don't no why they make them so short extra 10mm would help lol |
