Author Subject: Does this sound normal?!
Chr1sch
Hi gents
I've been paranoid since the day I bought it but it's sounding particularly rough today so would appreciate your thoughts...
She's an old girl, done 159k miles, serviced every 5k miles, golden oil, doesn't burn any, doesn't smoke, goes well (equal with a clio 172), starts without fail, but God it sounds like a bag of nails!
It's also had a richw rebuilt head and 16 new valves back in 2011 (8k miles ago)
It's done one Trackday in my ownership and will be doing another in feb, just hoping it'll keep going. Ultimately trying to establish if it's just sounding well used or a 'tapper' or just about to die lol
Video
Posted 5th Jan 2015 at 17:30
lj_6
Definately doesn't sound normal !the few things that I've had before that can contribute were a loose plug ! Worth checking those. and also checking the exhaust manifold. The nuts could have come loose. Try that. For now perhaps ?
Astra burg #365 Garrett Power
'99 bodied 6 track project
Posted 5th Jan 2015 at 17:33
Chr1sch
on a side note the harsher vibration is the bumper vibrating...
Chr1sch
ok will have a look at those asap, thanks
On reflection what I'm terrified of is the bottom end going...
Posted 5th Jan 2015 at 17:49
pete-gti
Spark plugs maybe , she old girl dot forget she been around want sound perfect lol
Posted 5th Jan 2015 at 17:59
Chr1sch
Slightly worried as I did the pugs about 500 miles ago lol
Posted 5th Jan 2015 at 18:00
cully
cracked exhaust manifold or loose plug ?
Posted 5th Jan 2015 at 18:09
Chr1sch
Thanks guys, could it be the gasket, I recently fitted a decat (which is coming off again...)
Cully your 306oc thread was worth it's weight in gold!
Posted 5th Jan 2015 at 18:14
Niall
This is what a light bottom end knock sounds like!
http://youtu.be/ZHVi1_pwvvw
Posted 5th Jan 2015 at 18:42
ash j
A blow where the exhaust manifold meets the head can make it sound like a 'tapper'.
Would be worth inspecting, and possibly replacing gaskets and tightening up.
Posted 5th Jan 2015 at 18:44
Does it do it from cold ? Or just when its warmed up ?
Posted 5th Jan 2015 at 18:47
cully
The crush ring gasket could yes they somtimes take a while to settle once they are fitted correctly Whistle
and im glad my OC thread is of use to some Smile Thumbs up
Posted 5th Jan 2015 at 18:53
Chr1sch
Only when good and hot
Posted 5th Jan 2015 at 19:06
Chr1sch
Also, it's always been run and continues to be run on 5w40 fully synthetic, could that be it? Ie too thin when hot?
Posted 5th Jan 2015 at 19:07
Take the brake thingy off the the end of the exhaust cam and see if it stops the rattle ?
I had the same problem but never found the problem
Posted 5th Jan 2015 at 20:11
Chr1sch
Ok I'll give it a try thanks
Posted 5th Jan 2015 at 20:15
Chr1sch
Not sure the phone picks it up well enough, it's definitley not that kind of metallic knock (I think/hope/pray)
Posted 5th Jan 2015 at 20:16
ryangti6
Definitely sounds like it's blowing to start with.
Put your head down by the sump and listen to see if the noise is louder. With a bottom end you usually get the nasty rattle just as you take the load off and the revs level, luckily you don't have that so hopefully that's not the problem
Ryan
Posted 5th Jan 2015 at 20:25
Chr1sch
Ok will so, thanks all, bloody hope it is blowing and not anything more serious. That said it doesn't have that lift off rattle of a bottom end or it increasing with revs
Generally it's a pretty noisy old engine, are they all like that?
Posted 5th Jan 2015 at 22:20
lj_6
They usually tap a bit anyway but it isn't usually that loud. I would definitely check plugs and then try get it on a ramp to inspect the exhaust manifold.
Posted 5th Jan 2015 at 22:22
Chr1sch
Great thanks, will do so ASAP :-)
Posted 6th Jan 2015 at 07:22
luke89
Did you get anywhere with this mate?
Posted 7th Jan 2015 at 19:37
