Author Subject: How to remove dash board support / steering column cover
demondriverdan
I've taken the dash out of the car but not sure how to remove the metal support that is behind it and on top of the steering column? There is a piece of sound deadening behind it I want to remove.
Rallye Race Car
Posted 10th Jan 2015 at 20:48
pugheaven
Undo the 3 bolts in the engine bay, 2 under the scuttle panel and 1 half way down where the brake lines run, once you have undone them you have 4 17mm nuts holding the metal steating column bracket, iirc the two top ones and the lower inboard ones are left handed threads and the one by the accelerator pedal is right hand thread and so is the bolt going through the 17mm nut
Posted 10th Jan 2015 at 21:44
demondriverdan
Cheers Ollie, hadn't thought about left handed threads.
Rallye Race Car
Posted 10th Jan 2015 at 21:30
pugheaven
You can just tear the soundproofing out though, it just covers the brake master cylinder nuts
I managed to pull 99% of that pit without taking it off. Bit fiddly tho.
Posted 11th Jan 2015 at 01:18
