Many thanks.
| Author | Subject: What length bolts do I need when using 20mm spacers? |
thomo6
Regular Location: York Registered: 17 Oct 2010 Posts: 104 Status: Offline |
Just wanting to know what thread length wheel bolts to use with 20mm spacers and standard 18mm off set alloys. Currently have threaded bars fitted that I want to remove and replace with bolts.Many thanks. |
MisterGTR
Senior User Location: Glasgow Registered: 05 Aug 2014 Posts: 675 Status: Offline |
As I've found out you'll have to measure it yourself. What I reckon is that 18mm of thread is presented to a standard hub. So you will need 38mm visible thread including the spacer. BUT I'm waiting on replacement bolts to confirm my measurements. ________________________________________ Turned 40 and in true cliched fashion buying one of the cars of my teenage dreams! |
thomo6
MisterGTR wrote: As I've found out you'll have to measure it yourself. What I reckon is that 18mm of thread is presented to a standard hub. So you will need 38mm visible thread including the spacer. BUT I'm waiting on replacement bolts to confirm my measurements. Thanks MisterGTR, I would appreciate any update once you have yours. |
MisterGTR
I tested out this morning. I don't have locking nuts or replacement spigots (I'm having to return the whole oz kit), so didn't do a full fit and drive. But the 2 I put tightened up properly, with no play in the wheel and you can see from the photo about 12mm is covered in copper slip which is what was in the hub (at least). The bolt was presenting around 19-20mm from the wheel. So I'm guessing there was more than 12mm of the bolt in the hub, it just didn't get coated in copperslip from the hub. Hope my rambling makes some sense and helps. MisterGTR has attached the following image: ________________________________________ Turned 40 and in true cliched fashion buying one of the cars of my teenage dreams! |
not likely theres more than 12mm in the hub, dont think theyre even that thick________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
MisterGTR
welshpug! wrote: not likely theres more than 12mm in the hub, dont think theyre even that thick Thanks WP. ________________________________________ Turned 40 and in true cliched fashion buying one of the cars of my teenage dreams! |
