Author Subject: 20mm spacers?
Nose
Hi guys, forgive my ignorance but i have no experience with spacers at all. Another forum member has put 20mm spacers on the rear so the wheels fill the arches a lot better. I love the way they look now and it suits the car 100% Cool My question is will these be the correct fitmet (including bolts) for my cyclones?
http://www.ebay.co.uk/itm/Peugeot-Pug-Hub-Centric-Hubcentric-Alloy-Wheel-Spacer-Kit-With-Bolts-/371062352674?pt=UK_Car_Parts_Vehicles_Automobila_ET&var=&hash=item56650a2b22
cheers Thumbs up
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 23rd Jan 2015 at 21:56
Take it your car isn't lowered? No way you coul fit 20mm spacers with cyclones if it's dropped at all I would have thought? And those wheel bolts are 60 degree tapered which are only for aftermarket wheels. Cyclones need flat seated bolts with washers unless you don't mind them working loose Thumbs down
Posted 23rd Jan 2015 at 22:26
Bolts need to be flat faced for cyclones
Posted 23rd Jan 2015 at 22:24
Ben_W
Formerly gpm
Bud, as I said in my PM, they are gonna be fine but if running cyclones as you say, you'll need tapered washers to give the flat seat on the bolt.....
See the bottom of this page....
http://www.mistertee.co.uk/9.html
Ben_W
Formerly gpm
Mines dropped 40mm and 20mm spacers on the rear make it close, but it's ok.....
I'm the member he's on about...
Are your arches rolled? I might be wrong but I thought once their dropped they will be to tight to the arches.
Posted 23rd Jan 2015 at 22:27
Might depend on the condition of the beam and tyres size/type. Also it will make it softer on the rear and load the bearings more than normal.
Ben_W
Formerly gpm
Nope.....all std.......
Posted 23rd Jan 2015 at 22:31
Ben_W
Formerly gpm
Had a refurbed beam before I bought it and running Michelin 195/50/15 tryes
Posted 23rd Jan 2015 at 22:32
Chr1sch
Just a warning, i've got solid beam mounts, and polybushed, lowered i think about 30mm and running 16's on a 205/45 tyre and they are catching on the outside edge.... - you'll be stuck with standard or equivalent 15's
Posted 26th Jan 2015 at 17:34
