Author Subject: DTA s80 map file
craig903
Hi i'm after a dtaS80 base map for a '6 does anyone have one? I've emailed Dta and they said they have not got anything like that there.
Thanks
208 GTI Owner
Posted 30th Jan 2015 at 19:06
"pugjim" on here could have helped
http://www.306gti6.com/forum/showthread.php?id=142251
post number 12
shame as he's not a member but try replying to one of the threads he's started as he'll get a reply that way
Posted 30th Jan 2015 at 19:21
that's his mobile from here - http://www.306gti6.com/classifieds/viewadvert.php?id=2
Posted 30th Jan 2015 at 19:23
craig903
ok thanks.
208 GTI Owner
Posted 31st Jan 2015 at 18:39
Gaz7612
Thread revival sorry,
Does anyone have a base map for a DTA S80 running Jenvey 45’s please?
Gaz
Posted 15th May 2019 at 13:47
pete_rallye
take it your running standard flywheel and crank sensor?
Lap of the 'ring
Posted 15th May 2019 at 19:24
Gaz7612
I am Pete yes mate
Posted 15th May 2019 at 21:11
pete_rallye
I can try and alter mine to run with your crank sensor and flywheel if you can find the timing figures for it.
Lap of the 'ring
Posted 15th May 2019 at 23:56
Gaz7612
Pete,
From what I can find, I believe the figures are:
117’ BTDC
60 teeth with 2 teeth missing.
Does that help at all?
Posted 16th May 2019 at 20:52
craig903
117 isn't correct, 114.5 is the figure you need.
208 GTI Owner
Posted 16th May 2019 at 22:29
Gaz7612
Thanks Craig
Posted 17th May 2019 at 06:34
Gaz7612
Has anyone got a base map for a gti6 running throttle bodies?
Just need something to get my 205 to the mappers
Posted 5th Aug 2019 at 13:21
RallyeP6
My GTi6 is running on Jenvey 45's and DTA E48, PM me if you need a map, its set up for the road.
Posted 10th Aug 2019 at 17:07
i'll point Jim this Way Wink
Posted 10th Aug 2019 at 17:58
jeffers Forum Admin
http://dtaforum.com/
There’s normally a set of base maps with the DTA ecu, use a Vauxhall or vw base map and just put the gti6 crank position figures in. Should get you running.
Team Running Engine again!
Team Negative Camber!
Posted 10th Aug 2019 at 18:51
I've just spoken to Pugjim and he's sent me the one he thinks it is,..
I'll put it somewhere safe if people want it just pm me! Thumbs up
Posted 10th Aug 2019 at 19:39
