Author Subject: Xsara air conditioning
orta
Hi all,
Considering a xsara estate hdi as a daily and found a good one but the air con doesn't work. Do they suffer the same problems as the 306? Or does it really just need "regassing"
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
Posted 31st Jan 2015 at 20:07
They tend to suffer a little less due to the engine bay seeming to be a little better shielded, so its probably only been inoperative a few years not ten LOL
Posted 31st Jan 2015 at 20:17
orta
Cheers mate. Still be same cost to fix tho?
CLUB BLACK RALLYE
Posted 31st Jan 2015 at 20:29
MisterGTR
You can take it to kwik fit who will only charge for regas if it works. And they can usually identify the problem.
Posted 31st Jan 2015 at 20:32
RetroPug
That's a good shout.
If you regas it you'll likely just be making the hole in the ozone layer bigger. LOL
My old 306 did have working aircon when I bought it...somehow!
Posted 1st Feb 2015 at 07:51
Puggitt
Ha! Finally something NZ has over you European lads! Haven't had a broken ac 306 yet.
Do your ones rot the pressure pipes in the front end?
Is that something that you guys will want from me for once LOL
Posted 1st Feb 2015 at 08:25
The two pipes that run along the front crossmember usually corrode through on the points they are mounted. That's the most common area anyway. I've had 2 306's with working AC so far out of about 7 lol
Posted 1st Feb 2015 at 09:59
MisterGTR
I've put new pipes on mine as I was refreshing the condenser etc anyway. Got a big tub of grease to cover the pipes in, once I've done my front end refresh.
I actually think it was the spring clip that ess broken on mine. Will get my old pipes pressure tested at some point.
Posted 1st Feb 2015 at 11:21
RetroPug
Pretty much. We aggressively salt our roads over here.
Posted 1st Feb 2015 at 12:24
