Author Subject: What does your 6 weigh?
I finally got round to bothering to put my 6 on a mates rolling brake tester on an ATL which weighs the cars axles to calculate brake efficiency. Been meaning to do it for ages as it's only round the corner LOL
Can't remember the weight of a standard full fat phase 2/3 6 with Aircon but mine is stripped with AC removed, rear wiper removed, spare wheel removed, all sound deadening removed, Airbags wiring and ECU removed, 330mm brembos, 17" Superleggeras, oil cooler, supercharger kit, MASSIVE front mount cooler bigger than normal high boost size, 2 not exactly light weight bucket seats, upper and lower strut braces, rear harness bar with very thick plating either side, still has sunroof and electric windows, also has a tig welded 2.5" full centre exit exhaust system with two large boxes and pretty thick pipework....
Wasn't expecting it to be much lighter than standard with all that lot but works out at 1065kg which isn't to bad! Could easily get one below a tonne without all the crap I've got on mine lol.
Posted 17th Mar 2015 at 19:20
pete-gti
Mine got be same or even less :-)
Posted 17th Mar 2015 at 19:58
It was 1148kg with me in it and a few bits and bobs in the back. You got a cage but smaller cooler lighter exhaust and no sunroof I presume? Should be similar really Thumbs up will be less once I get my carbon bonnet back on and might yet remove the sunroof....
Posted 17th Mar 2015 at 20:10
Mine is 995kg with a quarter tank of fuel. Or rather it was before the winter. Not really removed weight just moved it into the wheelbase and further back Smile
Only fibre bonnet but has lexan windows. Sunroof plated, heavy bucket seats and a 19 point welded cage
Posted 17th Mar 2015 at 20:50
eddy_gti6
My old astor was down to about 930kg with 1/4 tank of fuel
Posted 17th Mar 2015 at 21:05
That would be the one you cut a million holes in LOL
I could loose a bit more and may do yet but it's more of a road car than track so don't wanna go silly LOL
Posted 17th Mar 2015 at 21:17
pugheaven
Hopefully find out how much the dimma is in a week or so, probably find out that the carbon has made it more than standard lol
I hope to be under 1000kg with half a tank of fuel so it we be around 500hp per ton
Posted 17th Mar 2015 at 21:24
Lol that's about twice what mine is worked it out to be about 249bhp per tonne LOL
Just checked I did the same with my mk1 Leon FR Tdi and it was 1466kg with half a tank and a sub in the boot lmao fecking fat arse thing it is Laugh my ass off weighs more than that now it has heavier recaro heated leather interior and bigger 323mm front brakes...
Posted 17th Mar 2015 at 21:43
Status: Online
crikey, didn't realise those leons weighed so much, no wonder my E34 keeps up fine then LOL
Posted 17th Mar 2015 at 21:46
Christ... My Volvo v70 t5 weighed less than that LOL
I haven't gone silly on the weight loss, I suspect there is considerably more to be removed. But I am running full dash, hydro, extinguishers etc.
Posted 17th Mar 2015 at 21:49
the petrol ones aren't quick unless they've been modded and mapped.... My daily derv will still woop a 6 or civic type R lol
Posted 18th Mar 2015 at 07:50
Status: Online
I was refering to a mk2 diesel FR specifically, vs a 93 525 TDS LOL
Posted 18th Mar 2015 at 11:28
Lol fair play mines a mk1 PD150 now 300ftlb on a custom map with smooth torque curve unlike most that give you a lump making it feel quick but in actual road speed terms isn't that great... It could be pushed to 210ish Bhp and more torque on the current turbo but clutch wouldn't last to long so I'm happy with how it is at the minute.
Not sure what the MK2's weigh but would have been a 140 or 170bhp 2.0PD engine. Go well for standard cars but not as well as mine lol. Funny how an old BM is quicker tho LOL
Posted 18th Mar 2015 at 11:32
Status: Online
need to weigh the zx I think, but I know it started at 1150kg and each wheel is 6-7 kilos lighter inc tyre (x5)
other than engine its standard.
Posted 18th Mar 2015 at 13:06
