displaying posts 101 to 125 of 157
Pages (7): first .. 4 [5] 6 .. last
Author Subject: 044 pump killing engine
rich_w
Post #101
Have you got any idea how your swirl pot is constructed inside Olli? Do they provide a diagram or anything?
Contact Details:
07732 822546
Posted 23rd Mar 2015 at 16:38
pugheaven
Post #102
Not a clue! I got it from think automotive and that's the way the matey told me to plumb it in, I'll try and see if they have any diagrams :thumbs up
Posted 23rd Mar 2015 at 17:39
pugheaven
Post #103
Just had a look and not a lot of info on it to be honest it's the mocal fsp2, I'll have a better look when I finish work tonight but mocal or think automotive don't go into much detail like they have with dry sump tanks as the have diagrams for them Sad
Posted 23rd Mar 2015 at 17:52
Post #104
quote:
The three upper connections are -6JIC and the lower connection (to high pressure pump) is -10JIC.
that's all I've found, and really unless there's a blockage on the return to the tank that's all that could cause this, specifically as a test to just get the engine running it doesn't matter which way the smaller pipes are connected at all, you just wont get all the air out if the return to the tank isn't fed from the highest port.
Posted 23rd Mar 2015 at 18:07
pugheaven
Post #105
Pretty much all I found out, we definitely checked the return to tank as I remember using my girlfriends coffee mug to collect the fuel in... She wasn't to happy
Posted 23rd Mar 2015 at 18:13
pugheaven
Post #106
I'm also trying to find out why the 044 allows fuel to flow when it's de-energized, I'm guessing it does allow fuel to flow either way so then it can release the pressure in the line when the car is off
Posted 23rd Mar 2015 at 18:46
pete_rallye
Post #107
A lot of swirl pots have a restrictor in the return to the tank, I assume it is to keep the swirl pot slightly pressurised to keep it full and stop the fuel sloshing about, they aren't usually baffled or anything inside. If that is the case you will get some flow, as the injectors open the pressure will drop on the flow to the fuel rail and you'll get enough fuel to give it an idle. Some pumps have non return valves in them but they don't have anything in to stop fuel flowing through them when they aren't operational.
Was wondering if it didn't happen on Rich's tank because they sit that bit lower and also the flow is picked up from the bottom of the tank so there will be some restriction there. Your's won't be far off level with the fuel rail so you won't need much pressure to generate some flow.
Lap of the 'ring
Posted 23rd Mar 2015 at 20:07
Post #108
afaik the 044 will have a normal non return valve on its outlet, this only works one way.
Posted 23rd Mar 2015 at 20:13
pugheaven
Post #109
I think i removed the non return valve if it's the bit I'm thinking of, when I got the pump from think automotive it came with a fitting on the out let for a banjo fitting but it was around an 1" long so I guess the nrv was part of that
Posted 23rd Mar 2015 at 20:55
fatlapit
Post #110
Have u tried a normal battery instead of the race one??
Posted 23rd Mar 2015 at 20:56
pugheaven
Post #111
Nope, I don't have one yet...
I'm pretty sure it's an electrical fault and the fuel system is not to blame, weather it be something shorting out or the alternator not charging the battery so when the hp pump is connected it draws to much power and takes it away from the ecu etc
Posted 23rd Mar 2015 at 21:01
pete-gti
Post #112
Is it just cutting out?
Posted 23rd Mar 2015 at 21:04
pugheaven
Post #113
Yup as soon as I electrically connect the 044 pump
Posted 23rd Mar 2015 at 21:05
pete-gti
Post #114
Strange I'm running the 044 pump aswell , good as gold but I'm using the 3 bar fpr thow
Posted 23rd Mar 2015 at 21:10
Post #115
I'm going for duff alternator and not enough juice for the ecu when pump draws some lecky
pugheaven
Post #116
My 2 high boosts ran 044's and so did this before but I had a new one so sold the old one! Its not the pump as it primed and runs fine before the engine starts!
I'm using a different regulator because iv got the bigger charger
Posted 23rd Mar 2015 at 21:31
fatlapit
Post #117
Thats why id try a normal battery.
Posted 23rd Mar 2015 at 21:14
pete-gti
Post #118
Yea normal battery worth a shot, have you got to run the higher fpr?
Posted 23rd Mar 2015 at 21:16
fatlapit
Post #119
Race batteries ave no beans in them
Posted 23rd Mar 2015 at 21:20
pugheaven
Post #120
I would imagine so if rich/lynx fitted it
Posted 23rd Mar 2015 at 21:30
pugheaven
Post #121
I can't see the battery being an issue, if it starts the car the alternator "should" do the rest! I'm not running a heated rear screen, electric windows etc just the bare minimum
Posted 23rd Mar 2015 at 21:40
Post #122
gotta check, you'd kick yourself if you dismissed it!
Posted 23rd Mar 2015 at 21:42
pugheaven
Post #123
I will do but I'm starting to think alternator, hope it is the battery as changing the alternator will be a right pain in the arse
Posted 23rd Mar 2015 at 21:45
fatlapit
Post #124
But if there is a current demand the battery will back up the alternator. Uve already let the battery go flat which isnt advised with a race battery
Posted 23rd Mar 2015 at 21:49
pugheaven
Post #125
Well it didn't go dead hence I stopped and waited for it to fully charge! That's what I mean if the alternator isn't charging the battery or working as it should its relying on purely the battery power
Posted 23rd Mar 2015 at 22:06
