Author Subject: SOLD 48mm throttle bodies
jorg
first things first these are NOT jenveys but copies of jenveys. i got them off ebay the other month but I am not going to using them now.
what you get is the following:
2 x 48mm DCOE bodies 118mm in length
4 trumpets
Bosch TPS sensor
fuel rail
lever
more pictures can be found here: http://s261.photobucket.com/user/gcrallying/library/48mm
the injectors in the pictures are not included as they were only used to show how the fuel rail works.
looking for £350 delivered for the lot. if you have any questions or would like further information please ask
306 2.1 S16 Tarmac Rally Car
Posted 7th Apr 2015 at 12:00
daver6
Why aren't you using them? Which manifold is used?
Wishbone Polybushes available
Posted 27th Mar 2015 at 12:04
jorg
I am not using them as I have my 45's all setup now ready to go. I'm sure you could get a 48mm Satchell manifold made for them.
Posted 27th Mar 2015 at 12:07
jeffers Forum Admin
I will add I have a set of these awaiting a manifold, the quality seems pretty good and they appear from the measurements to be compatible with all the necessary accessories from jenvey. Are these 48mm all the way through jorg or tapered to 45mm? Mine are tapered to 45 mm... Just wondered really, good luck with the sale!
Team Running Engine again!
Team Negative Camber!
Posted 27th Mar 2015 at 12:18
jorg
just had a look at them and they are 48mm all the way through Smile
Posted 27th Mar 2015 at 12:32
Tarmac terror
Would 48's be suitable for a std unmodified engine??
if so, could be VERY interested..
TT
Posted 27th Mar 2015 at 13:38
TT
Not really - should be 45s
Posted 27th Mar 2015 at 15:15
daver6
Where did you find them on eBay?
Half thinking I could sleeve them to 45mm
Posted 27th Mar 2015 at 17:51
Tarmac terror
Was thinking the same myself TBH....
TT
Posted 28th Mar 2015 at 00:16
easier to find 45's.
Posted 28th Mar 2015 at 06:11
jeffers Forum Admin
This was one of the last sets I seen on the bay although he does seem to put stuff on in fits n starts!
http://ebay.to/1H9JJMZ
Posted 28th Mar 2015 at 07:31
jorg
i got mine from here: http://www.ebay.co.uk/itm/Throttle-Body-Itb-Kit-48mm-tps-/121559389615
Posted 28th Mar 2015 at 09:02
daver6
Thanks guys, I was wondering why I couldn't find them. Sleeving them wouldn't be an issue at all. In fact, I've seen them opened out to 48mm for example at filter side and head port side so they're tapered, essentially, sleeving it would do this.
That said, I'd much rather have the proper bodies for the job
Posted 28th Mar 2015 at 09:11
jorg
SOLD Smile
