Author Subject: S/c stuttering
psjunkie
i have recently bought a low boost sc 6. It's a phase 1. When the tank gets down to maybe a 1/4 full or so it stutters when giving it some
Only way I can describe it is power then nothing then power again
Does it mainly in 2nd and 3rd
I'm wondering if the fuel pump is struggling to pickup below this.
Any ideas?
1997 P1 Gti 6 Charged
Posted 28th Apr 2015 at 20:12
pugheaven
Will be fuel starvation, phase 1 tanks are not baffled like 2/3s, either fit a phase 2/3 tank or fit a swirl pot and uprated pump
Posted 28th Apr 2015 at 20:18
psjunkie
I've just noticed from scanning a previous owners posts he's fit a
mrdeey
Put a new Walbro gss 341 in place of the original , and a replacement Bosch 3 bar regulator from a golf , now working fine
now new booted , boosted and flying again!
Could this be something to do with it? Or is it defiantly the non baffled tank?
Posted 28th Apr 2015 at 20:19
psjunkie
Thanks for the reply pugheaven
Posted 28th Apr 2015 at 20:20
6waysforward
ph1 fuel pumps and poss the tank are different.
Farmer used to have a lb ph1 and he bought my ph2 pump and tank as he had starvation issues.
Think even standard ph1s get fuel starvation.
Get a swirl pot fitted or get a used ph2 tank and pump. Thumbs up
Posted 28th Apr 2015 at 20:23
6waysforward
f**k it, you beat me to it LOL
psjunkie
I'll get a swirl pot as I cba changing the tank. I'll just mount it where the spare used to be. Any pointers on what to go for and what pump to use?
Posted 28th Apr 2015 at 20:25
6waysforward
Pretty sure you could retain the standard pump with a swirl pot seeing as its not pressure thats the problem.
You would need a rich w jobbie to mount under to boot floor but join the fing que as i need one to LOL
Posted 28th Apr 2015 at 20:31
pugheaven
Get the swirl pot from rich w and a 044 pump, rich could probably get you a deal on the pump too
psjunkie
Cheers lads !
First charged 6 I ain't got a clue haha.
Posted 28th Apr 2015 at 20:33
pugheaven
I would imagine you would need another pump after the swirl pot! The fuel will take the easiest route with the least resistance so would just return to the tank from the pot plus you wouldn't get the pressure to the regulator
Posted 28th Apr 2015 at 20:34
6waysforward
This is a good point, didnt think about it returning.
Maybe i will shut up and let ollie answer the questions now. Yes
Posted 28th Apr 2015 at 20:39
I have a brand new rich W upside down swirl pot sat at work doing nothing..... Shall we start the bidding at £300 LOL
Posted 28th Apr 2015 at 20:51
In all seriousness changing the tank is a much easier option and cheaper!
Posted 28th Apr 2015 at 20:53
psjunkie
Means dropping beam and trying to get a 20 year old tank out tho ??
Would any swirl pot do ?
Posted 28th Apr 2015 at 21:09
pugheaven
You don't need to drop the beam to change the tank! Wiring would be the issue, phase one has a separate pump and sender unit and phase 2/3 are one unit so the wiring for that would need changing!
I personally would go down the swirl pot route, that way it's already fitted for when you go high boost Smile
Posted 29th Apr 2015 at 05:55
Ben_W
Formerly gpm
As pughaven says.
I think it's 4 bolts to remove the tank. Need to disconnect the handbrake cables first as they are (on a Ph2 anyway) held by the tank straps.... Just disconnect the three fuel lines and the elbow from the filler, do the 4 bolts and out it comes.
Just be careful undoing the nuts. The nuts and studs on mine were crusty as you like. Managed to shear one stud and I was even being heavy handed...
Posted 29th Apr 2015 at 07:06
Yup that's pretty much it. I'd just take the wiring plug from a phase 2/3 as well I presume it's only live and earth for the pump and input and output for sender.... 4 wires isn't difficult to solder. But yes if you are ever going to think about high boost you could do the swirl pot. But it's quite expensive... Rich W ones are £175 plus a Bosch O44 plus all the extra pipework clips mounting brackets etc etc it soon adds up to a good few hundred quid.
Or a cheap tank 4 rusty bolts a filler neck to remove and a few wires and clip on pipes.
Posted 29th Apr 2015 at 07:56
rich_w
The issue is he's put a Walbro in place of the standard pump - the way the pickup is designed on the Walbro pumps mean you get this starvation issue.
As others have said, get a swirl pot and Bosch 044, or change the tank and fit a known good OEM pump.
Contact Details:
07732 822546
Posted 4th May 2015 at 13:30
