Author Subject: What gearbox have you got in your high boost Rallye/GTI6?!!
thomo6
We have lost third gear in our high boost track Rallye this weekend while at Blyton. What gear box do other use in their HB cars?
Trying to decide whether to fit a 5 speed box or another 6 speed or are we likely to have the same issue again with a 'standard' box and need to consider something else?
Any advise would be much appreciated.
Posted 10th May 2015 at 15:14
fatlapit
I use a hdi box on my turbo
Posted 10th May 2015 at 16:26
pugheaven
The hdi box is slightly stronger but the ratios wouldn't suit the supercharged cars, I my self have 1st 2nd 5th and 6th shot peened and cyro dipped and straight cut dog engagement 3rd and 4th
I believe Ross aka superchargedblack has a spare set of the straight cut gears if not contact KAD but would be more expensive that from Ross due to not being a group buy
The 5 speed vts, s16, xsi box's are not any stronger as far as I'm aware
Posted 10th May 2015 at 17:56
hdi box is not any stronger than any other 5 speed box.
Posted 10th May 2015 at 17:59
thomo6
So is the common consensus that replacing it with another standard 6 speed box will just end up with the same issue happening again at some point?
Posted 10th May 2015 at 20:44
pugheaven
Yup unless you drive like a fanny in 3rd and 4th
Posted 10th May 2015 at 20:46
miles
VTS and most later BE3R & BE4 box's are weaker than the S16/M16 box's due to the finer teeth arragement used for refinement on the later models, which plaque the 6 speed box's for the same reason
www.pugracing.com
Posted 10th May 2015 at 21:14
