Author Subject: Front bushes
Cjwatson27
Whilst swapping over subframes i decided to replace the bushes on the bottom arms. I've already got berlingo p bushes fitted but wanted to do the front ones how do you remove them do you need a press ?. I've got some purple poly bushes from when it was a xsi I was going to fit unless there a big no no. Many thanks Chris Thumbs up
Posted 16th May 2015 at 22:36
burnout21
Drill the rubber out then use a saw to cut the outer shim.
Posted 16th May 2015 at 23:11
Cjwatson27
Is that for the front round one mate ?
Posted 17th May 2015 at 00:27
6waysforward
http://www.306gti6.com/forum/showthread.php?id=151372&page=2
See half way down the page.
Posted 17th May 2015 at 10:29
Cjwatson27
Cheers I might see if I can get someone to do them with a press mine aren't moving for love nor money
Posted 17th May 2015 at 11:52
chisel and twat them out.
Posted 17th May 2015 at 12:24
