Author Subject: Cat Fitting Kit
RetroPug
As above, anyone got a new cat fitting kit kicking around before I go to dealers/ebay?
Posted 17th May 2015 at 16:14
I've had dealer ones when I had my S16 as getting the right one was a nightmare
I've also had numerous standard eBay / ECP / Andrew Page ones, without any problems, and for about a third of the price of dealer
Posted 17th May 2015 at 16:16
RetroPug
Fair enough. Thanks for the info.
I was under the impression that the dealerkits were universal for all larger petrol engined 306s?
Posted 17th May 2015 at 18:57
jord294
I can highly recommend Hoffman sports cat
Posted 17th May 2015 at 21:08
RetroPug
I only need a cat fitting kit. Laugh my ass off
Posted 17th May 2015 at 21:27
mik
I know it is off-topic, but I looked at these when I was looking at cat options (ended up getting my OE one welded), and wondered if they were any good. Maybe someone could write a FAQ on cat replacement options?
Cherry Rallye SOLD
Posted 17th May 2015 at 21:46
RetroPug
That FAQ will probably become more and more useful as time goes on!
I'll post up pictures of the repair I'll get done to mine.
Posted 18th May 2015 at 12:08
RetroPug
Bumping this, I have loads of cat fitting kit parts lying around, the problem is I have all of the bits but I'm not sure about which bolts are the correct length as I have various lengths here. I'm aware that it is the "middle length" bolt out of the kit but I can't be 100% sure which of the bolts I have would be that length.
Is anyone able to give me the length of the correct bolts? Both overall length and distance from the head/taper to the thread? Any info that would help me determine whether or not I have the correct parts or I'd have to buy more bits would be very much appreciated.
Posted 26th Jun 2016 at 13:09
cully
pick one you can get the nut started without compressing the spring
pick a short one you will be cussing
pick a long one you will sound like an OC members tractor
Posted 26th Jun 2016 at 14:01
RetroPug
I did the first one, but it didn't compress enough so maybe it is long.
I have acess to a ramp but I don't want to obtain that access, drive the car a long way without much of an exhaust (my cat outlet pipe has now snapped again), and then find I don't have the correct parts.
I have bolts which are shorter than the ones I used but if I used the long ones and my other ones are shorter, I don't know whether or not they are the medium, correct ones or the ones which are too short.
Posted 26th Jun 2016 at 14:13
RetroPug
Bump, anyone able to tell me the correct length to use?
Posted 26th Jun 2016 at 20:13
scotzman
I could measure the length of the two sizes I didn't use.
Posted 26th Jun 2016 at 20:36
davidmartin
Done the sigma not that long ago, and honestly I think everything is so distorted through the heat, it's trial and error, couple of washers on the old kit and a £4 gsf ring sorted it for me.
pet hate, the cat
Posted 26th Jun 2016 at 20:39
scotzman
The two sizes I didn't use were, complete length 65.5mm and 72mm.
No idea if I used the correct pair but they went on easy enough and it doesn't leak.
Posted 26th Jun 2016 at 20:43
RetroPug
Thank you, much appreciated. I'll see what I've got!
Posted 26th Jun 2016 at 20:49
RetroPug
Those are the two sizes I have spare in a box. I do not know what size is currently on the car and whether or not it is correct. Anyone else able to help?
Posted 28th Jun 2016 at 18:34
cully
il add a bit more confusion!
just had a rummage in my bolt box, i have 3 different length bolts all used, i also have 3 different length compression springs too!
Posted 28th Jun 2016 at 19:47
RetroPug
Brilliant! Yeah I think I have various springs as well, perhaps I need the same bolt but a longer spring then.
A while ago I bought multiple kits and struggled to make any of them fit correctly.
Posted 28th Jun 2016 at 21:17
I've always found that when its a struggle to get the nut on for the first thread or two the setup is then pretty good at keeping itself sealed. Probably more awkward for me though as i do it laying on my back under the car making access much harder. LOL
Posted 28th Jun 2016 at 21:36
i just bought an o.e kit when i fitted the engine 6 years ago and its still on now!
Posted 28th Jun 2016 at 23:44
cully
cat-manifold fixing kit 179875 £14.99 retail from pug
Posted 29th Jun 2016 at 15:08
