Author Subject: Firing but not starting
jmgti6
Recently bought a Gti 6 which was advertised as spares or repairs. Stripped it down to find 8 bent exhaust valves. After reassembling it all it try's to fire but won't quite start. It's got a spark and it's getting fuel. Any suggestions? Crank sensor looks new. Cheers
Posted 22nd May 2015 at 15:27
demondriverdan
Easy suggestion is to check the inertia switch hasn't tripped? Red button by the ECU. I think it cuts the fuel so probably isn't the cause but worth checking anyway
Rallye Race Car
Posted 22nd May 2015 at 16:09
daver6
Immobiliser??
Wishbone Polybushes available
Posted 22nd May 2015 at 17:18
how are you checking it's "getting fuel"?
can you physically see fuel being forced out of the feed line when disconnected from the rail?
(i.e. - pipes are not wrong way around?)
Posted 22nd May 2015 at 17:44
chiefton
Check your earths are on?
cherry rallye daily (the money pit)
Posted 22nd May 2015 at 18:06
heliosphan
When you were rebuilding, did you remember to reattach the cylinder head? I can't count the number of times I've fallen foul of this simple mistake. Well worth a quick check: it can stop the engine from firing.
Posted 22nd May 2015 at 19:24
LOL
Posted 22nd May 2015 at 21:08
jmgti6
All sorted. Thanks for your replies. Timing was out, runs very nicely now.
Posted 17th Jun 2015 at 20:48
scotzman
Timing was out so far that it wouldn't start and you didn't bend valves?
Posted 17th Jun 2015 at 20:50
