Author Subject: Running a 306Gti6 OBD1 ECU in an 2001 OBD2 Xsara VTS - Help need
Conundrumical
Hi,
I own a 2001 OBD2 Xsara VTS, which had worked properly for just 5% of the time, due to constant electrical issues.
The legendary "Antipolution fault" has been such a frequent guest, that I drove it with an OBD Scanner attached, so I could get rid of it. It began with loss of power, however there was nothing constant about it - it sometimes lacked high end power, some other time it worked properly from above 4k rpm. Then there was the fuel consumption, at times the car didnt rev above 3k rpm and consumed above 30l/100km. Bats**t crazy. You name it, Ive had it.
Long story made short, after a chat with my mechanic we came to the conclusion that the only reasonable thing, thats left to be done is to try running an "old" a.k.a one big connector pre OBD2 Gti6 ECU.
However, apart from reading that it has been done - hence is doable we do not know much more. There wasnt much more info there.
I know that Ill need
- A 306 OBD1 Ecu
- A 306 wiring loom
- 306 coils
- "some sensors"
And.. and..
So heres the question - How to get rid of the forsaken OBD2 ECU and run a "Normal OBD1" one.
Youre my only hope. Might sound a bit dramatic, but its true.
If you have any experience with this topic/such a conversion, please help. Sad
Posted 27th May 2015 at 18:05
it will not be a simple task, and I doubt actually possible as the gti6 ecu does not drive the instrument cluster, which the Phase2 xsara does.
IF you believe the ecu is at fault, then get a ph2 xsara ecu, I cannot fathom why you and your mechanic believe the only "reasonable" thing is to replace it for ancient tech, when the ph2 xsara is more efficient and you actually can do a diagnostics check on it with standard EOBD tools.
Posted 27th May 2015 at 18:32
Conundrumical
Ive seen two threads about Xsaras born as OBD2 cars, that had been converted into OBD1.
So it can be done. About the instument cluster - One of the converted cars didnt have a working fuel level gauge - I can live without that Wink.
I believe that going OBD1 is the only way because of the cars constant lambda/car problems,
Which, although much time had been spent on fighting them, remain.. unresolved.
Posted 27th May 2015 at 18:57
it would be much easier to fit a replacement lambda sensor.
Posted 27th May 2015 at 19:12
Conundrumical
Already tried all the lambda magic. Apart from that, the benefit of running an obd1 ecu, is the fact that I can get a full exhaust system without the cat and maybe later a remap from superchips, which isnt available for the obd2 one.
Posted 27th May 2015 at 19:41
barrym
You def do not want a remap from superchips lol
Black Rallye occassional toy
Posted 27th May 2015 at 19:53
Conundrumical
I might want the chance of getting one Wink
Posted 27th May 2015 at 20:17
