Author Subject: Rear Calipers Q
iplay
The driverside rear caliper stops sliding when the mounting bolts are tightened.
I have repalced the bolts, slide pins and seals. The calipers slide easily until bolt starts to tighten.
Damage to caliper or trailing arm possible?
Posted 2nd Jun 2015 at 11:32
bent caliper bracket if the bolts are new and threads good
Posted 2nd Jun 2015 at 11:39
try it on the other side
Posted 2nd Jun 2015 at 11:40
iplay
Thumbs up
Posted 2nd Jun 2015 at 11:52
jord294
i've found that if you tighten to recommended torque they can go tight.
so i just do them up to 80Nm
Posted 2nd Jun 2015 at 12:05
iplay
thanks - that has been my solution for the last 2 sevices.
I will swap over the brackets but they are new parts in good condition.
I still think there is an underlying issue.
Could the caliper itself get twisted if it was in a knock or the rear trailing arm (bolt threads?)?
Posted 2nd Jun 2015 at 12:25
swapping brackets means pulling off the wheel bearing.
never had issue with going tight with bolts done to correct torque, under torque is not a wise idea, especially on brakes!!!
Posted 2nd Jun 2015 at 12:29
