Author Subject: pas relocation brakets
stef306
wanted pas relocation brackets im aware they are available new from rich_w but just seeing if anyone has some second hand items.
cheers
1990 205 gti6 supercharged
Posted 10th Jun 2015 at 00:02
I found my old ones in the shed, here they are as they stand:
I've somehow lost the bushes that i used in the sump so they may not be much use to you, i think i just used m10 studding & half nuts to locate the pump.
Interested?
Posted 10th Jun 2015 at 21:01
stef306
yes i can made everything else give me a pm Smile
Posted 10th Jun 2015 at 22:48
rich_w
Who makes these ones? And what's the extra bit that sticks out?
Stefan - I would check these fit first - looking at them, they space it out further from the sump than mine - you may find the pump hits the chassis cross member or rad as on the PAS 205s we've done it's very tight.
Contact Details:
07732 822546
Posted 11th Jun 2015 at 00:46
I had the above ones laser cut for mine a few years ago, the extra bit that sticks out is to attach a tensioner to the alternator.
The part that sticks out was quite close to the radiator, and the pump was fairly close to the cross member so it would be worth checking the pictures in my project thread if you want to see it all in situ to check you are happy with positioning etc. Smile
Posted 11th Jun 2015 at 06:50
stef306
It's hard to tell the clearance as they will be in a 205 not a 306 and I wouldn't be using the alternator mounting.
Posted 11th Jun 2015 at 16:21
Would a photo showing the distance between the sump and crossmember be any use to you?
Posted 11th Jun 2015 at 16:30
stef306
Yeah it would help thanks
Posted 11th Jun 2015 at 16:43
Posted 11th Jun 2015 at 17:07
stef306
Do you not have one with the brackets and pump in place?
Posted 11th Jun 2015 at 17:46
Afraid these are the best photo's i've got, i can go and show the dimensions of the brackets if you want?
Posted 11th Jun 2015 at 20:21
stef306
every little thing will help me get a idea
Posted 11th Jun 2015 at 23:20
rich_w
Contact Details:
07732 822546
Posted 12th Jun 2015 at 20:40
rich_w
My brackets in a 205
Contact Details:
07732 822546
allanallen
Doh! That ain't fitting stefanie!
Facebook
Posted 12th Jun 2015 at 22:56
c_j_m
Got a full rich w setup here.
Inc all brackets, pump, high and low pressure lines, aux tensioner with rich w pulley.
After £150 delivered.
Posted 19th Jun 2015 at 17:39
stef306
only need the brackets
Posted 19th Jun 2015 at 22:36
