displaying posts 1 to 1 of 1
Author Subject: Engine Parts / Ancillaries
rich_w
Chaps,
I have some engine parts for sale. All parts are removed from a 2003 Citroen Xsara VTS (same engine as the GTi-6), so you won’t find newer or better condition!
• Set of 4 x coil packs - £30 delivered
• Front engine mount / ancillaries bracket - £25 delivered
• Flywheel - £25 delivered
• PAS pump - £30 delivered
• Starter motor - £35 delivered
• Alternator - £35 delivered
• Coil pack cover - £15 delivered
• Inlet manifold complete with TB, all support brackets, fuel rail and injectors - £60 delivered (note, this has the later style black injectors – to use on a GTi6 you would need to fit some of the green injectors)
• T/Stat housing - £20 delivered (this has two of the holes plugged with threaded bosses which can be removed, as the VTS only uses one sensor)
• Brake servo vacuum pump with mint pipework (the small hosetail on the T piece is normally broken on these) - £25 delivered
Contact Details:
07732 822546
Posted 11th Jun 2015 at 17:25
