Author Subject: Standard throttle body question.
martinh
On the engine going in my 205 the black unit on the front of the throttle body is cracked and the sensor plug is mashed.
Would there be any problems in sealing the crack up and not plugging the sensor in?
Or should i stop being a pikey and get a replacement?!
Posted 29th Jun 2015 at 18:19
its just a heater element so yeah it'll be fine.
Posted 29th Jun 2015 at 18:24
martinh
Winner! Thanks.
Guess its worth sealing the crack up because as its part of the breather system or else i guess it will get messy?
Posted 29th Jun 2015 at 18:37
looks like the other outlet for the EVAP is snapped off too
is it bunged up / filled?
Posted 29th Jun 2015 at 19:07
martinh
Haven't looked to be honest mate!
Posted 29th Jun 2015 at 19:12
On the throttle body for the supercharged setup the whole black plastic area is done away with and just a metal sheet put over with silicone around it. Just do that if it's all cracked up.
Posted 1st Jul 2015 at 18:02
martinh
Thats a good shout mate! What happens to the breather pipe off the cam cover then?
Posted 1st Jul 2015 at 18:35
I would just source another black plastic piece, saves f**king about modifying crap needlessly.
Posted 1st Jul 2015 at 18:40
I use an oil catch can. Though there's almost hardly ever any oil in it at all mostly condensation vapour have to empty it every couple of months. Engine doesn't inhale it's own oil then either.
Posted 1st Jul 2015 at 20:22
Run the breather to atmosphere and then get the metal plate from Rich to cover where the broken heater is.
Job sorted.
Posted 1st Jul 2015 at 23:54
eddy_gti6
I have just put a blank over mine and not plugged it in. not had any issues with it like that so you will be fine
Posted 1st Jul 2015 at 23:59
