Author Subject: Brembo set up.
Craig g
My Rallye when I bought it came with brembo calipers running 288mm discs. I was considering changing these over to a wilwood set up I've left over from my 205 gti6 days but was wondering what the alternatives would be if I kept the brembo caliper set up in terms of disc options...
Preference is to run a 15" wheel so that might limit my options even further...
Is what I've got the only option?
Craig
Posted 2nd Jul 2015 at 19:32
yes.
a select few 15" wheels will go over them, changing the discs wont make any difference unless you move the caliper too, clearance wise theyre quite similar to the wilwood kit
Posted 2nd Jul 2015 at 19:46
Craig g
Thanks... Hopefully they fit over the Speedline SL2118's I've just bought!
Posted 2nd Jul 2015 at 20:17
I hope you meant UNDER Razz
They did fit under the Magnesium version of that wheel, the 1508's, also Team Dynamics pro race 1.2.
Posted 2nd Jul 2015 at 21:10
Craig g
I meant under! Doh....👍
Posted 2nd Jul 2015 at 21:12
They needed a 3mm spacer on the btcc 15s speedlines
Posted 2nd Jul 2015 at 23:15
Craig g
Where's the best place to get 3mm spacers from?
Posted 3rd Jul 2015 at 07:23
aaron6
Probably a machine shop. I made my ones. Which tbf I don't use now. If your at pugfest you can pick them up from me.
Posted 4th Jul 2015 at 05:32
Craig g
Thanks for the kind offer... Unfortunately I won't be at pug fest!
I'll get a set made up then if not available off the shelf.
Although I think I might still remove the brembos and go with my wilwood set up as the brake squeal from brembos is a tad annoying!
Posted 4th Jul 2015 at 09:02
