Author Subject: Rattle from engine bay
ben01328
During a long road trip yesterday i noticed a noisy rattle coming from the engine bay. Its a metal tiny sound (technical term there) LOL
it's most noticeable above 3k rpm when you let off the throttle and it was also present at cold start this morning but disappeared when warm at idle.
the car doesn't drive or respond any different to normal.
A mechanic mate had a very quick look at it and thinks it could be the pulleys near the charger.
He noticed one did have a bit of play in it but very minimal.
Anyone had a similar issue or seen it before?
Cheers Thumbs up
Team Boosted Hyper
Team 330mm Cool
Posted 19th Jul 2015 at 16:44
jeffers Forum Admin
Have a look at the heat shield that bolts to the exhaust manifold behind the back cam cover, they're known to come loose and create that exact issue! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 20th Jul 2015 at 00:04
ben01328
Hi jeffers, Ive had a good look round the back of the engine and cant find or feel anything thats loose or anything that was touching or rubbing.
Are there any other bits commonly known to cause this sort of rattle?
Team Boosted Hyper
Team 330mm Cool
Posted 20th Jul 2015 at 20:46
ben01328
Hi Guys, found the issue! Turned out that the lamda sensor had worked slightly loose and the washer on that was what was rattling.
Quick tighten up and problem solved.
Funny that something so small was causing such a horrendous noise
Team Boosted Hyper
Team 330mm Cool
Posted 31st Jul 2015 at 21:17
mocinim
Clearly youve not met my daughter
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 31st Jul 2015 at 21:31
