BLACK RALLYE - phoenixWHITE RALLYE - valliant
| Author | Subject: cat convertor best to buy |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Hi gents whats peoples opinions on the best non original cat to buy peugeot want 6 to 7 hundred for a new one do any others perform as well original system only ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
RetroPug
Probably best off spending 70-80 odd quid on a good, 2nd hand genuine one.Has it failed emissions or has the outlet pipe cracked and fallen to bits? If the 2nd one get it repaired at an exhaust place. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
sbolly
Junior User Location: Sutton Coldfield Registered: 31 May 2015 Posts: 67 Status: Offline |
http://www.autobits.co.uk/store/view_product.php?product=6946 ^^ Bought this for mine, will be fitting it tomorrow will try and let you know details on fit and quality etc. Went for the steel monolith option, ramps the price up a bit but worth paying for as it'll last forever. ________________________________________ '97 Platinum Silver GTI 6 |
mocinim
None of the above its actually fine at the moment bit smelly not sure it will pass mot in jan just preempting the enevitable but dont want to spend out till required will start work on the bottom of the car soon will all be oe in the end Just thought there maybe an alternative out there any idea who manufactures the peugeot one ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
chiefton
Seasoned Pro Location: cranleigh Registered: 09 Dec 2012 Posts: 1,195 Status: Offline |
if you cab get a gen pug one the difference is night and day to a nasty pattern one________________________________________ cherry rallye daily (the money pit) |
ash
Six Addict Location: Chelmsford Registered: 25 Mar 2003 Posts: 7,520 Status: Offline |
I've got a genuine cat you can have for £100 |
mocinim
What age you got on that cat ash ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Cheers bolly keep us posted seems super cheap think ill wait a month and get a new pug one it is a full to standard rebuild pricy but will never need another ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim wrote: ill wait a month and get a new pug one it is a full to standard rebuild pricy but will never need another £600 odd for a genuine one IIRC ________________________________________ ![]() |
mocinim
Cheers dan tis 681 plus surcharge unless you give them your old cat on the spot wallet raping ball bags ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
RetroPug
The genuine cats give the best performance, and also last quite well. In fact their ability to pass emissions often seems to outlast their ability to stay in one piece. The outlet pipe is the main weak point.Your issue could possibly be a sensor? ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
mocinim
Hi retro what sensor would you suggest has brand new lambda (bosch) and brand new ICV (marelli) have considered the map sensor advice is welcome ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
RetroPug
Maybe CTS but it could well the cat causing it to fail.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
sbolly
mocinim wrote: Cheers bolly keep us posted seems super cheap think ill wait a month and get a new pug one it is a full to standard rebuild pricy but will never need another ________________________________________ '97 Platinum Silver GTI 6 |
mocinim
Cheers bolly did it make a difference to you power output ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
RetroPug
It almost definitely will. It doesn't mention if it is a 100 cell, 200 cell etc. Also it is definitely a physically smaller casing than the std. cats which are quite large in order to offer less flow restriction.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
mocinim
Hi ,retro what other symptoms do you get with a dickky CTS________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
sbolly
mocinim wrote: Cheers bolly did it make a difference to you power output Yeah you bet, coupled with the Jetex system I've noticed a great improvement in the drive, mostly acceleration. It's much sharper in lower gears and pulls really well through the higher ones. If you do go for that option i posted in the beginning, go with the steel monolith as technically you shouldn't need to ever replace it. And comes with two year warranty ________________________________________ '97 Platinum Silver GTI 6 |
