Author Subject: Ignition On When Off
Eddleston
Have any of you guys had this problem before?
Battery light on when ignition off, then off when the key is turned one notch.
https://youtu.be/Dq_6HObjGU0
(Don't worry about the blowers bit, I'm off to try some relays and a spare panel)
Posted 8th Aug 2015 at 12:12
either a damaged ignition switch or a short in the wiring at the front of the car around the two engine loom plugs or fan loom
Posted 8th Aug 2015 at 12:49
Eddleston
So if I had pulled apart the fan connector to sort out a rusted connection and just run that one connection outside the connector... I may have a problem. Unsure That's the only thing I can think of.
Posted 8th Aug 2015 at 14:11
another thought, if the blowers have stopped check the relay under the steering column, that might be a bit melty causing a short
Posted 8th Aug 2015 at 15:11
Eddleston
Yep, had a look at that, somewhere said it was the green one furthest to the right. I was expecting/hoping to find a melty mess but no, it's perfect.
Roll eyes
Posted 8th Aug 2015 at 15:26
Eddleston
Big Connector
Smaller Connector
Fan Connector
The nasty one is the one with the wire by-passing it.
Got the multimeter on them earlier and a lot of the connections have continuity between them, but I suspect that would be the case as a lot of them come from the battery.
Posted 9th Aug 2015 at 19:14
