Thanks
208 GTI OwnerTurbo'd '6 project - work in progress
| Author | Subject: Satchshift with dpengineering manifold |
craig903
Regular Location: whitstable Registered: 08 Jul 2013 Posts: 273 Status: Offline |
Hi would anyone know if the satchshift kit would fit with a dpengineering manifold and down pipe? I suspect not but I'm not sure. Thanks ________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
craig903 wrote: Hi would anyone know if the satchshift kit would fit with a dpengineering manifold and down pipe? I suspect not but I'm not sure. Thanks I wouldn't have a clue ...but what I do know is make sure you fit the Satchell shift ....amazing bit of kit |
craig903
Yep I've heard that too but I don't know if there is enough room for the bar to go threw the bulkhead because off the down pipe.________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
I doubt you will have enough room, not a lot of space with the standard exhaust manifold and down pipe |
demondriverdan
Should fit ok with a Maniflow 4-2-1 as that takes up less space?________________________________________ Rallye Race Car |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Does anyone else's Satchshift reverse selector rattle a bit when changing gears?I think second is a bit tired in my box which makes the change bloody hard too when cold... As others have said it's mega right under there so unless your manifold is indeed smaller than standard i don't fancy your chances |
heat shouldn't many any noticeable difference if you have the right oil.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
craig903
I've had a look under my car the down pipe goes right in front off where the hole needs to be drilled threw the bulkhead ________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
Chr1sch wrote: Does anyone else's Satchshift reverse selector rattle a bit when changing gears? I think second is a bit tired in my box which makes the change bloody hard too when cold... As others have said it's mega right under there so unless your manifold is indeed smaller than standard i don't fancy your chances Not mine |
