Author Subject: 4 Pot Caliper Options
Lecktorious
aka G.
Hi all,
I am currently running AP 4 pot calipers with 330mm rotars. To get a pad to fit without fouling the bell I need to trim the inner edge of the pad off, but having done this 2 or 3 times I'm getting a bit scunnered with the constant rubbing and vibrating through the pedal. I figured with the cost of new bells and hassle of continuously filing down pads I might be as well with a new set-up.
Are there are direct fitment 4 pot calipers from the current Peugeot range (or other applications) that I could use with an off the shelf disc and pad? I did consider a set of 406 Brembo calipers but I'm unsure how big a disc I coul use with these?
Any help is appreciated!
Cheers.
'98 Nile Blue 306 GTi 6
Posted 30th Aug 2015 at 17:17
I'd shim the caliper up.
Posted 30th Aug 2015 at 19:03
Lecktorious
aka G.
Don't really have the time, tools, patience or inclination to fanny about any further tbh Welshy. Plus I don't know what other issues I could cause doing so either. I'd rather have a fit and forgot solution.
Posted 30th Aug 2015 at 19:08
