Author Subject: painting the sump
mocinim
Hi all thinking of painting my sump whats the proces for removal and replacement what tools will be required gaskets etc and whats the best method for painting etch primers then paint or just clean then paint or other
cheers Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 2nd Oct 2015 at 18:23
monty-69
If its an alloy sump its a waste of time imo Smile
Posted 2nd Oct 2015 at 19:04
mocinim
Its getting pitted are they still available to buy do you know
Posted 2nd Oct 2015 at 19:06
just clean it up and whack some hammerite silver on it, job jobbed
Posted 2nd Oct 2015 at 19:29
eddy_gti6
I just bought some aluminium paint worked fine for me and cheap as chips Wink
Posted 2nd Oct 2015 at 19:39
mocinim
Excellent was hoping for a simple job did you paint in situ or di you remove to paint if removed what do i need to consider for the job apart from oil sump plug washer etc
Posted 2nd Oct 2015 at 19:50
eddy_gti6
Just degrees it and paint the lot. That's all i done
Posted 2nd Oct 2015 at 19:54
dont bother, 1 -itll flake 2- wont dissipate heat quite so well.
degrease and wd40.
Posted 2nd Oct 2015 at 20:11
mocinim
Cheers welshpug its already clean just pitted and naf looking the block is freshly painted just looking to spruse moose the old girl next i want to address the top end cam covers etc any recomendation for cleaning dont want to change from original just want them to look better any ali cleaners recommended or will they do more bad than good
Posted 2nd Oct 2015 at 21:50
