Author Subject: Oil temperature sensor plug
6box
Someone seems to have cut the oil temperature plug/ wiring off my loom.
Does anyone have one of these or know of where I can buy one, don't really want to buy a whole new loom.
Thanks
Posted 3rd Nov 2015 at 21:45
You can get the connectors off ebay, I think the seller is something like brands hatch performance from memory the connector is a junior power timer or or something like that.
If you have a little search you should see them on eBay.
Next problem is the crimping tool, I got a cheap one made by Bergen which does the job but isn't perfect for the terminals used. Alternatively you could always try getting away with pliers or solder to do the job, there are proper crimping tools out there but I didn't fancy investing in one with the intention of only making a single loom for myself. Smile
Posted 3rd Nov 2015 at 22:30
6box
That's brilliant cheers buddy!
Will this one work then?...
http://www.ebay.co.uk/ulk/itm/171388372591
As looking at a mates 306 I notice it's just a single wire going to the plug although it's s two pin sensor?
Posted 4th Nov 2015 at 09:05
earth circuit is via the engine earth same as the dash coolant sender/switch.
the oil temp sender will only have one pin even if its a two pin plug, there isnt a single pin variant.
Posted 4th Nov 2015 at 09:15
Ask Ryan (pug306) he's sending me a loom plug for nothing.
Posted 4th Nov 2015 at 10:19
Yeah that looks like the one. You may need to chop out a bit of the housing to get it to fit over the sensor on that one, some connectors have like a slot to suit different connectors. (I know that probably doesnt make sense, but you'll see what i mean if you look at the sensors connector then look at the one in the link).
Posted 4th Nov 2015 at 16:44
