BLACK RALLYE - phoenixWHITE RALLYE - valliant
| Author | Subject: subframe mounting bolts |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Hi guys need some subframe bolts 12x175 69 bolt no longer stocked by peugeot looking for new cheers ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
just place an order or go to a nut n bolt shop. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
do some lateral thinking, berlingo/partner are the same front end.3509 56 SUBFRAME FIXING SREW 12X175-69 ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
Was just going to the nut n bolt place but cheers for the berlingo info im sure thell be easy enough to get at the correct shop Peugeot lists them as screws wanted to be sure i got the correct parts nothing worse than to stop a job for the sake of a few miss managed bolts ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Place an order !! With who do you sell !!!________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
try that number with your local dealer, its different to the 306 numbers bu the same spec bolt.most stuff not stocked can be ordered easily. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
Apparently peugeot no longer supply this part for the 306 according to my local will challenge them with the part spec for the berlingo bolt size etcAll other parts for the subframe i have on order through them ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
Sorry just re read this wandering around london trying to do to many things will work on the suggested cheers welshpug________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
mocinim
welshpug! wrote: do some lateral thinking, berlingo/partner are the same front end. 3509 56 SUBFRAME FIXING SREW 12X175-69 Cheers again welshpug peugeot list these as restyling for the 306 and multiple other vehicles and are correct replacements ![]() ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
