| Author | Subject: Inlet manifold support bracket |
6box
Newbie Location: Norwich Registered: 23 Jan 2014 Posts: 41 Status: Offline |
After the support bracket that sits under the inlet manifold and is bolted underneath? |
Pretty sure I have one of those kicking around in a box of bits. I shall confirm later.________________________________________ ![]() |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
think there are twoone is in the centre of block to centre of manafold second is from gearbox front edge to throttle body end of manifold |
6box
thanks for that.yeh i have the one near the gearbox i think sits around the throttle body area? just after the on that sits in the middle of the manifold |
There are indeed 2 and they are important. I had a 6 in at work the other week with a misfire and eventually turned out to be an air leak on the inlet gasket and once I took the manifold off its support bolts were missing. The gasket had been warn away where the manifold was flexing up and down. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
