Author Subject: Battery light issue
Ok so I have no battery light on first click of the ignition or second and when I fire up the car the battery light comes on after a min (dim but on) I have put another alternator on and getting 14.4 volts at the battery so something must be a miss somewhere for the battery light not be working as it should ? Any ideas ? Had the dash out recently to do matrix but everything works so doubt I missed something.
Have checked earths and they are all as should be all be it someone bodged the 2 earths on the box that I have fixed now ?
Posted 23rd Nov 2015 at 13:45
mocinim
Loose bulb ?
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 23rd Nov 2015 at 15:24
I doubt it bud as it lights up when car running but I am leaning towards it being clock related
Posted 23rd Nov 2015 at 15:35
mocinim
Only mentioned as one of my side repeaters does the same kind of thing the vibration of the engine and all that!!! Has a loose bulb due to be replaced with everything else Smile
Posted 23rd Nov 2015 at 18:05
I think it may be a fuse issue as doing a search fuse 28 causes problems and the rear wiper is also not working ?
Will have a look when I get back to the car in a couple of days ?
Posted 23rd Nov 2015 at 18:09
tvrfan007
I was going to say, look at the rear wiper fuse, it'll be blown and the cause is the relay mounted on the rear wiper motor that will be corroded.
I recall that fuse does a lot, i.e. i suspect your electric windows are also not working.
Had this on my HDi many moons ago.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 24th Nov 2015 at 09:45
It's a Rallye so keep fit Windows but will check the fuses
Posted 24th Nov 2015 at 10:06
As above, that blue relay on the rear wiper is the cause of many gremlins. Once removed/replaced end of issue.
It may not fix your problem, but definitely worth a look mate. Thumbs up
Posted 25th Nov 2015 at 09:32
Fuse 28 it was - changed that and it all came back to life as it should
Posted 25th Nov 2015 at 20:34
Glad you found the issue mate, useful info to know.
Posted 26th Nov 2015 at 07:37
