Author Subject: Lexus Lights
shabusta
Anyone know of an adapter for these, or how to rewire them?
Lexus light plug and wires
Stock rear cables, phase three.
Posted 28th Nov 2015 at 08:13
You can buy link looms for Lexus lights if you insist on fitting the awful looking things.
  • Posted 28th Nov 2015 at 09:57
    shabusta
    hahaha, its more a safety thing, i found the OEM ones either as they are or by age are too dark,
    and i have had people complain that it is hard to see me.
    and i got the lexus lights for $40.
    Posted 28th Nov 2015 at 09:59
    matt16v
    When's the body kit going on?
    Must be something up with yours if they're too dim. Nice and bright when working correctly.
    1999 Astor Grey GTi-6 OEM+
    Posted 29th Nov 2015 at 10:41
    shabusta
    Hahaha oem light i cant plug the lexus lights in different connections
    Posted 29th Nov 2015 at 10:47
    kill it with fire!!!!!
    Posted 29th Nov 2015 at 10:49
    Worst "mod" you could do,...
    Looked s**te in 1997! LOL
    Posted 29th Nov 2015 at 10:51
    shabusta
    Only body kit i will ever do is a MAXI!
    Are we talking about the lights or the kit?
    Posted 29th Nov 2015 at 10:54
    RetroPug
    If your rear lights are too dim something is probably wrong.
    Posted 29th Nov 2015 at 16:59
    Puggitt
    What this guy said! It'll be a bad earth, pretty common fault here with 306's in NZ
    Posted 30th Nov 2015 at 05:57
    shabusta
    New Zealand!!!! good to sea someone else down here in the southern hemisphere.
    they work "fine" i think it is just the bulbs getting old, i'll either steal them from the lexus lights,
    or this week or next do up some wiring ideas to just cut them and re do it for the new lights.
    Posted 30th Nov 2015 at 06:20
    mik
    Start with cleaning any dirt out of light housings and checking/cleaning connections and bulb holders as well as cleaning and re-securing earth points. Renewing wiring to earth points with thicker wire will also help, as wiring resistance increases with age and corrosion causing voltage drop and dimmer lights. Renewing bulbs with LED bulbs might help too - they have lower current draw than standard bulbs.
    Those Lexus lights look awful and won't address above problems, I'd stick with standard lights.
    Cherry Rallye SOLD
    Posted 3rd Dec 2015 at 11:01
