(again) and wanted to know if the cheaper ones are any good as they are half the price.
http://www.gsfcarparts.com/parts/fuel-emissions/mixture-formation/lambda-sensor
| Author | Subject: Lambda required |
Kenan
Regular Location: Exmouth Registered: 20 Oct 2013 Posts: 307 Status: Offline |
Hi Guys, my car is running rich so I want to change the Lambda sensor. They have got 35% off at GFS this weekend (again) and wanted to know if the cheaper ones are any good as they are half the price. http://www.gsfcarparts.com/parts/fuel-emissions/mixture-formation/lambda-sensor |
Ben_W
Formerly gpm Location: Lutterworth Registered: 01 Sep 2007 Posts: 2,941 Status: Offline |
General consensus with lambdas is that the aftermarket ones run on a slightly different range I think it was so don't work as well.Go with a genuine Bosch one if you can get one ________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
Kenan
Think I found one - http://www.amazon.co.uk/Bosch-0258003717-Oxygen-Sensor/dp/B0068MV4U4 I think the part code is 0258003717, anyone able to confirm? |
stan_306gti6
Yep, that's the correct number for the genuine part. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
http://www.lambdasensor.com/main/bosch/price.pl?item=0258003717 ________________________________________ ![]() |
Kenan
Thanks guys, one on the way.Now lets see if I can change it myself or end up at a garage . . . |
Have faith. You'll be fine.________________________________________ ![]() |
You'll end up rounding the nut on the old one and taking it to a garage to get changed |
stan_306gti6
Easiest thing to do is to cut the cable at the sensor end and then use a deep 22mm socket. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
