Author Subject: HELP! ABS indicator lights up and all exterior lights disappear
mughal
Hello.
I got a problem with my 306 GTI6 .
ABS lamp lights up periodically, and when it lights up, then all exterior lights on the car disappear.
I must then turn the light switch over to AUTO, then alle the exterior lights Works fine.
Anybody have any tips on what might be wrong ?
Thanks in advance.
Moeen S. Mughal
Posted 8th Dec 2015 at 08:19
6waysforward
Auto lights. That must be a euro option.
Sounds like an earth fault on the abs pump.
Or a power fault to the pump.
Do the exterior lights work manually from the stalk when the abs light is off?
Posted 9th Dec 2015 at 21:45
mughal
Thanks for answer.
Sorry, forgot to write it, yes it's a europe car ( Norway).
When the ABS lamp dont lights up, then all the exterior light comes automatically on when i start the car.
And when the ABS light lights up, then I have to manually turn the light button to Auto.
(Sorry for bad english).
Moeen S. Mughal
Posted 11th Dec 2015 at 09:56
mughal
Update:
After driving the car 30 km and I braked hard several times, the ABS light disappeared and all exterior lights came on automatically as it should be. This has happened twice. The reason I braked hard is becuase I dont use the car so often and it started getting rust coating on the brake discs.
After the car has been parked for about two hours and I start up the car, the ABS light comes back on, and all exterior lights do not work. I must then turn the light switch over to AUTO, then all the exterior lights comes on.
Any ideas people?
Moeen S. Mughal
Posted 16th Dec 2015 at 11:52
mughal
Does anyone have some tips?
Moeen S. Mughal
Posted 12th Jan 2016 at 14:20
mocinim
Dash switch for your auto
Is it rotary if so pull it out wd40 bath it then clean with circuit board cleaning spray if it is that !!! Will help
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 12th Jan 2016 at 14:25
mughal
Great, I will try that Smile thanks a lot Smile
Moeen S. Mughal
Posted 12th Jan 2016 at 14:48
mughal
I try'ed that now, it did not helped Sad
Any other tips?
Is it any earth-point near by the wheel base/brakes? Becuase when I have breaked hard several times, the ABS lamp disappear, and the ABS system work fine. And the light works fine too. But after the car has been parked for couple of hours, the fault comes back...
Moeen S. Mughal
Posted 13th Jan 2016 at 19:48
