Author Subject: Frustrated with the wind!
justsamo
Hey guys,
I'm wondering if someone can help here, I've read through the forum regarding this but I'm stumped..
Basically if you are driving along anything higher than 60mph, you can hear wind coming through the middle of the top of the door (drivers).. If you push the seal you can feel the wind coming through!
It hasn't let water in mind, I'm wandering whether it's the seal or if the door isn't sat right..
Anything I can adjust before attempting to find a new seal?
It's been like it ever since I had to sort the door loom when everything stopped working!
Any help is appreciated!!
Cheers.
Posted 8th Dec 2015 at 21:05
mocinim
Did you take the door off to fix !did you take off a hinge instead of removing the centre pivot bolt ???
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 8th Dec 2015 at 22:34
tvrfan007
My hdi had had the door bent over from the rear top corner by a pikey. Caused exactly that.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 8th Dec 2015 at 22:38
justsamo
Yes I did take the door off but only removed the check strap and replaced it (phase 3).. All the hinges stayed put!
Posted 9th Dec 2015 at 07:55
mocinim
At a guess if its not letting in water and the only issue is at speed would suggest its just the seal gone soft as tvrfan suggested is the door stright are the surrounding gaps to the roof sill and back quater even if all are !!! Would replace the seal speak to pug306 has lots of cheap bits will have a spare im sure Smile
Posted 9th Dec 2015 at 11:08
justsamo
Got a bad feeling the door isn't quite straight to the frame..
Any way I can force it back?
Wind the windown down and push? Pikey style?
Posted 9th Dec 2015 at 14:51
mocinim
Yep go easy make sure you bend at the correct point best not done in cold weather
Posted 9th Dec 2015 at 15:00
justsamo
I'll give it a bash, but should the door be open or closed when I give that a go?
Posted 9th Dec 2015 at 20:23
craig903
A trick is to get some very small rubber hose and feed it inside the door seal. makes it stiffer
208 GTI Owner
Posted 9th Dec 2015 at 20:26
mocinim
Open you wont be able to force it closed youll need to take it just past stright to change the memory of the metal only a few mm past stright and it will spring back a little as said go easy
Posted 9th Dec 2015 at 20:44
