displaying posts 26 to 50 of 54
Pages (3): 1 [2] 3
Author Subject: VTS rack fitted - odd behaviour...
Is the sensor the same. Large xsaras use different management. Just a thought.
Otherwise I'd say tracking possibly
Posted 6th Jan 2016 at 17:22
Chr1sch
Hmmmm good point, is the sensor the same!? Anyone know for sure? Tracking was also done when fitting so worth a look for sure...thanks!
Posted 6th Jan 2016 at 17:53
Chr1sch
just drove it up and down the road again, its got an insanely strong self centering motion and the pulsing with lock on is pretty horrible, even at low speed.
Genuinely worried this is going to ruin the upcoming trackday in Feb at Silverstone Sad
Posted 8th Jan 2016 at 14:19
pug_306
Did you swap the high pressure pipe buddy.?
1992 205 GTi6
205 Turbo 340bhp
Posted 8th Jan 2016 at 14:45
have you done the tracking?
Posted 8th Jan 2016 at 14:54
derp, missed the posts above LOL
Posted 8th Jan 2016 at 14:55
Chr1sch
With the high pressure pipe about an inch or so had to be replaced (just extended be flexi hose by that amount with insanely over spec'd hp hose of the same internal diameter etc)
Yes tracking was done immediately after, however it was fouling the box badly so it was done again to
Limit that, could that be a potential issue?
I run 205 section tyres so it was fouling pretty badly immediately after fitting (much worse than the old original rack)
Any ideas?
Posted 8th Jan 2016 at 19:59
demondriverdan
I have very little fouling running Direzzas which must be 215s and a Xsara ph2 rack. Only on full lock do they rub.
Rallye Race Car
Posted 8th Jan 2016 at 20:04
I have PHAZE 1 rack & 205/50/16s Dunlop DZ03gs & they foul just ?
Posted 8th Jan 2016 at 20:13
Chr1sch
Post #35
Jesus I don't know what's going on, they only foul at full lock right but pretty badly (they did a bit as standard)
I'm totally lost on what to do now
Posted 8th Jan 2016 at 20:55
pug_306
Post #36
Did you fit the GTi6 RAM ?
1992 205 GTi6
205 Turbo 340bhp
Posted 8th Jan 2016 at 20:59
Chr1sch
Post #37
I don't believe so, but not 100% as I didn't fit it, could that be it!?
Posted 8th Jan 2016 at 21:00
pug_306
Post #38
You need the GTi6 Ram fitted to stop it fouling, but still sounds like a fluid restriction issue
1992 205 GTi6
205 Turbo 340bhp
Posted 8th Jan 2016 at 21:02
Chr1sch
Post #39
Right ok thanks all of that is very useful thank you!
Posted 8th Jan 2016 at 21:03
demondriverdan
Post #40
Yup, the ram controls the lock so if you didn't change it you'll have more right lock than the rest of us, hence why you get more fouling.
I'd suggest changing the ram and as part of that you'll have to change the fluid so see how it feels after that? Might be worth changing the pump at the same time if you've got all the fluid out anyway?
Rallye Race Car
Posted 8th Jan 2016 at 21:33
Chr1sch
Post #41
Yes good idea, I will report back, thanks chaps :-)
Posted 9th Jan 2016 at 08:21
Post #42
Its not the ram.
Strong centering steering means the geometry is set up wrong. Get it checked again - its only toes anyway. Go for slight toe-in of 3 minutes overall max.
Posted 9th Jan 2016 at 21:06
Post #43
Oh and make sure the tyre pressures are bang on before its done. If running a diff you'll find it drags about with un-equal tyre pressures.
Posted 9th Jan 2016 at 21:08
Chr1sch
Post #44
No diff but I'll be sure to get all the gro done again, thanks appreciate it!
Posted 9th Jan 2016 at 23:48
Post #45
The Beauty about the VTS Phaze 1 rack is you can use all your old pipework as well as being 2.4 not 2.6 as with the Phaze 2 which you need to adapt Thumbs down
Did you flush the old pipework through before fitting or did the garage ?.....sounds like a very small piece of rust flake /foreign object has entered the pipe work ?
Could a small flake of the damaged pipe have entered ...either before you stripped or after ?
I've seen stuff which has been taken off cars which has been stored end up with this problem ...
My suspicion would be something got into the pipework / Fluid ?
You still have to use the GTI6 Ram on both Phaze 1 & Phaze 2 or fouling happens & hits 6 speed box housing ....
Posted 23rd Jan 2016 at 15:42
Chr1sch
Post #46
I beleive so, my mate fitted it at his garage but given the fluid needs to cme out again anyway I'll be sure to make sure it is flushed
I had no idea about the phase 1 vs 2, it's been a total ball ache and I'm regretting it massively
It's going in on the 21st so we'll see then...
Posted 13th Jan 2016 at 21:17
Chr1sch
Post #47
So it's back and it's perfect :-D All down to the Xsara ram being fitted so not sure if it was also knackered but the steering is now so so good!
Posted 23rd Jan 2016 at 11:38
pug_306
Post #48
Glad its all sorted buddy ;-)
1992 205 GTi6
205 Turbo 340bhp
Posted 23rd Jan 2016 at 11:43
Chr1sch
Post #49
Me too lol it was bloody horrible before, lessons learnt n all that...
Posted 23rd Jan 2016 at 11:44
mik
Post #50
Great news to hear it is all sorted. I've got one fitted and love it - I think it is what the Rallye should have had from the start.
Cherry Rallye SOLD
Posted 23rd Jan 2016 at 15:17
Pages (3): 1 [2] 3
